Fluidampr with Eagle Crank Problem #1396089
03/02/13 05:44 PM
03/02/13 05:44 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I went to put on a Fluidampr (bought used) for my 440/505 build. I put the damper on and found that it does not go on the crank snout deep enough. After some researching I see the snout on the Eagle crank is about 1.75" while a stock 440 crank is around 2.5". So I see my problem, but what do you guys do? Do you switch out the center of the Fluidampr? Looks like it needs to be about 3/4" shorter to work?
Thanks.
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396090
03/02/13 05:53 PM
03/02/13 05:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
With the timing gear against the crank I would say the it is shorter on the nose.Did you do any other meassurements?
Re: Fluidampr with Eagle Crank Problem [Re: Clanton] #1396091
03/02/13 06:15 PM
03/02/13 06:15 PM
Danville, NH
Danville, NH
The timing gear does go against the crank (bottomed out), but with it in that position its about an 1" too far out to line up the pulleys
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396092
03/02/13 06:29 PM
03/02/13 06:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I would say if you have a stock damper take them both to a machinest and have the hub milled down to match.Do you have someone to take it to?
Re: Fluidampr with Eagle Crank Problem [Re: Clanton] #1396093
03/02/13 06:31 PM
03/02/13 06:31 PM
Danville, NH
Danville, NH
I suppose having it milled would work, but just wondering if there is a different hub out there..
No, I do not know of anybody who could do that..
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396094
03/02/13 06:40 PM
03/02/13 06:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Is there a part # on it?
Re: Fluidampr with Eagle Crank Problem [Re: Clanton] #1396095
03/02/13 06:48 PM
03/02/13 06:48 PM
Danville, NH
Danville, NH
No part number.. here is a pic.. I would guess take an 1" off the snout it would work? but I don't know..
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396096
03/02/13 07:27 PM
03/02/13 07:27 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
That hub looks like its from an ATI damper. They have different pn hubs for chain,belt or gear drive. Hope this helps.
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396097
03/02/13 07:31 PM
03/02/13 07:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
so you don,t have a damper just a hub!BDS sells a hub and maybe look at RBS superchargers.com for a used one is all I can think of rite now.A hub new is 125$ I think.
Re: Fluidampr with Eagle Crank Problem [Re: Clanton] #1396098
03/02/13 07:38 PM
03/02/13 07:38 PM
Danville, NH
Danville, NH
I have the damper itself and it is a fluidampr, I just unbolted the hub from the damper. It is suppose to be for a 440, and I think it would work fine with a standard 440 steel crank, its just I have an eagle crank..
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396099
03/02/13 07:43 PM
03/02/13 07:43 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
When you install the damper,how much clearence from the back of the damper to the timming cover?
Re: Fluidampr with Eagle Crank Problem [Re: fbs63] #1396100
03/02/13 07:55 PM
03/02/13 07:55 PM
Danville, NH
Danville, NH
IMO too much.. about an 1" It is also bottomed out on the crank at that point as well and cannot go on anymore.
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396101
03/02/13 08:57 PM
03/02/13 08:57 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Thanks.
Are you sure that your crank is going to be ok? It may be possible that you are attempting to shoot yourself in the foot.
Re: Fluidampr with Eagle Crank Problem [Re: Mopar-Al] #1396102
03/02/13 09:06 PM
03/02/13 09:06 PM
Danville, NH
Danville, NH
Thanks.
Why wouldn't my crank be ok?
Maybe I should ask this question.. what balancer are those with Eagle 505 strokers using?
RS23L7 4-Speed
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396103
03/02/13 09:25 PM
03/02/13 09:25 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Well, the reason why I asked was, I haven't never had to use any type of special cut balancer on a b rb block fit. I have a fluid on my eagle crank and it fits, so does a stock damper. I'm wondering if you got something wrong with that 1 particular crank. I do not claim to no it all, or even close, but I do know that I hadn't seen that big of a difference on a crank snout as of yet.
Re: Fluidampr with Eagle Crank Problem [Re: Mopar-Al] #1396104
03/02/13 10:36 PM
03/02/13 10:36 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I have used tons of Eagle Cranks and never had any dimensional problems as you suggest(OP), unless I am misunderstanding what you are trying to do.
As for a suggestion, I use nothing but ATI dampers on all race(even hot street)builds.. Sure there are cheaper alternatives, but I stick to what works for me...
MB
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396105
03/02/13 10:40 PM
03/02/13 10:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have a Fluidamper on my Eagle crank with no issues
But I don't remember it being a two piece unit though,in fact I have never seen one in the last four I installed on engines I have built
Gus
64 Plymouth Savoy
Dana 60
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396106
03/02/13 11:01 PM
03/02/13 11:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you saying the chain is not in line or that the
damper sticks out to far... if the cam lobes line up
with the lifters and the chain is straight then its
the damper.... as said already both the BB and SB fluid
units I have are 1 piece(might have to call them)
Re: Fluidampr with Eagle Crank Problem [Re: MR_P_BODY] #1396107
03/02/13 11:15 PM
03/02/13 11:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Are the small blocks and big blocks diff. a small block bolt is longer..I assume the stoud was too ?
Re: Fluidampr with Eagle Crank Problem [Re: Mopar_Mike] #1396108
03/02/13 11:28 PM
03/02/13 11:28 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Wondering why there is 2 oil lip seal grooves on the hub? Is that hub a 6 bolt pulley system? A bb chevy is 3 for the most part, but has about the same ID diameter, just a few thou smaller.
With race season right on us, I sure hope you can get the 2 issues sorted out quick.
