What to use to clean up deck of block and heads?
#1394558
02/27/13 11:21 PM
02/27/13 11:21 PM
Posts: 302 Middle of the US
Verga
Middle of the US
What is the best way to clean up the deck of block and the heads? Pistons are still in the block.
"Im supercharged, might explode in your face"
Re: What to use to clean up deck of block and heads?
[Re: Verga]
#1394559
02/27/13 11:23 PM
02/27/13 11:23 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Pull it and send it to the machine shop....and then wash it with soap and water when it comes back. That is the absolute best and most accurate way though not the cheapest. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: hemidup]
#1394566
02/28/13 11:01 AM
02/28/13 11:01 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
I use a scraper on the iron parts, block and/or heads and if it's aluminum very carefully with a razor blade as to not gouge the aluminum. Finish it off by hand with a scruffy pad.
[Re: gregsdart]
#1394570
02/28/13 01:03 PM
02/28/13 01:03 PM
Guitar Jones
If you can't feel anything on the surface with a fresh razor blade, the gasket won't know the difference.
I know, just me being a bit anal.
