What to use to clean up deck of block and heads? #1394558
02/27/13 11:21 PM
02/27/13 11:21 PM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
What is the best way to clean up the deck of block and the heads? Pistons are still in the block.
"Im supercharged, might explode in your face"
Re: What to use to clean up deck of block and heads? [Re: Verga] #1394559
02/27/13 11:23 PM
02/27/13 11:23 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Pull it and send it to the machine shop....and then wash it with soap and water when it comes back. That is the absolute best and most accurate way though not the cheapest. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: What to use to clean up deck of block and heads? [Re: Verga] #1394560
02/27/13 11:25 PM
02/27/13 11:25 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
What do you mean? Is it rusted? Or just gasket material stuck. Aluminum or cast heads? My first thought when I read the post was disassemble and hot tank, then clean it all fresh
Re: What to use to clean up deck of block and heads? [Re: Mopar-Al] #1394561
02/27/13 11:40 PM
02/27/13 11:40 PM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
Just gasket material, cast heads. Swapping heads only. Not pulling rotating assembly apart.
Re: What to use to clean up deck of block and heads? [Re: Verga] #1394562
02/27/13 11:50 PM
02/27/13 11:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
then the first think you should do is mask off the cylinders while doing the cleaning so you don't get crap in them, the heads you can clean separately. we used to use a gasket cutter and cut cardboard circles that fit snugly in the bores. for something like that i would almost always start off nice fresh razor blade scraper changing blades as required. if there's a lot of rust you can use cookies (roloc discs) but need to be careful not to remove metal. they are abrasive so you need to be VERY careful about getting that crap in the engine like the bores or lifter valley. you should be able to get the majority of stuff off with a blade.
Re: What to use to clean up deck of block and heads? [Re: Verga] #1394563
02/27/13 11:54 PM
02/27/13 11:54 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
razor blade,laquer thinner,tooth brush size wire brush.
Re: What to use to clean up deck of block and heads? [Re: Clanton] #1394564
02/28/13 01:05 AM
02/28/13 01:05 AM
Re: What to use to clean up deck of block and heads? [Re: Cab_Burge] #1394565
02/28/13 01:23 AM
02/28/13 01:23 AM
MN
hemidup Offline
hemidup  Offline
MN
And a patiant wife who you upseted her daily soap opera program. lol
Jerry Williams.
Re: What to use to clean up deck of block and heads? [Re: hemidup] #1394566
02/28/13 11:01 AM
02/28/13 11:01 AM
Guitar Jones Offline
I use a scraper on the iron parts, block and/or heads and if it's aluminum very carefully with a razor blade as to not gouge the aluminum. Finish it off by hand with a scruffy pad.
Re: What to use to clean up deck of block and heads? [Re: Guitar Jones] #1394567
02/28/13 12:01 PM
02/28/13 12:01 PM
gregsdart Offline
gregsdart  Offline
If you can't feel anything on the surface with a fresh razor blade, the gasket won't know the difference.
Re: What to use to clean up deck of block and heads? [Re: Cab_Burge] #1394568
02/28/13 12:09 PM
02/28/13 12:09 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
LOTS of laquer thinner
If you like drag racing, support your local track.
Re: What to use to clean up deck of block and heads? [Re: CHAPPER] #1394569
02/28/13 12:40 PM
02/28/13 12:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
a DA works great.
Re: What to use to clean up deck of block and heads? [Re: gregsdart] #1394570
02/28/13 01:03 PM
02/28/13 01:03 PM
I know, just me being a bit anal.
Re: What to use to clean up deck of block and heads? [Re: Guitar Jones] #1394571
03/01/13 02:07 AM
03/01/13 02:07 AM
gregsdart Offline
gregsdart  Offline
Nothing wrong with a little extra tlc
