383 Magnum #1394344
02/27/13 11:14 AM
02/27/13 11:14 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline OP
P
SouthEast Michigan
Over the years we have done a fair amount of stock muscle car engines. We have a good package for the resto guys in 383 and 440 engines.
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394345
02/27/13 11:15 AM
02/27/13 11:15 AM
SouthEast Michigan
P
P
SouthEast Michigan
Dyno sheet
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394346
02/27/13 11:17 AM
02/27/13 11:17 AM
SouthEast Michigan
P
P
SouthEast Michigan
Pic #2
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394347
02/27/13 12:21 PM
02/27/13 12:21 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
sweet
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394348
02/27/13 01:39 PM
02/27/13 01:39 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Care to share the particulars of the build?
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394349
02/27/13 02:50 PM
02/27/13 02:50 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
That looks like a good engine to raffle off
Re: 383 Magnum [Re: GTX MATT] #1394350
02/27/13 04:58 PM
02/27/13 04:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 383 Magnum [Re: JohnRR] #1394351
02/27/13 05:34 PM
02/27/13 05:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Torquey little guy, ain't he? 3.38 stroke?
Re: 383 Magnum [Re: topside] #1394352
02/27/13 07:12 PM
02/27/13 07:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just noticed the water temp , is that a little low ? Would it have made more power , though maybe not a lot more, if the engine were up to operating temp ?
Re: 383 Magnum [Re: joshking440] #1394353
02/27/13 07:18 PM
02/27/13 07:18 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
At least the heads dont leak.
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394354
02/27/13 07:40 PM
02/27/13 07:40 PM
Did you jet it at all? What do the spark plugs look like? The BSFC look a little on the rich side to me, maybe not though on your local fuel
Re: 383 Magnum [Re: Cab_Burge] #1394355
03/01/13 12:34 AM
03/01/13 12:34 AM
this world
drifter Offline
drifter  Offline
this world
What HP do you think the engine would have made if it ws run at operating temp. like 180-190 140 seems kinda low for testing isn't it?
Re: 383 Magnum [Re: drifter] #1394356
03/01/13 10:44 AM
03/01/13 10:44 AM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
sumone made a very good choice in cam selection!
Re: 383 Magnum [Re: GTX MATT] #1394357
03/03/13 11:19 AM
03/03/13 11:19 AM
SouthEast Michigan
P
P
SouthEast Michigan
This Block was fully machined on our CNC block machine, Torque plate honed, our valve job, just like all of our builds. It is 4.290 bore, Diamond shelf stock pistons, eagle rods, stock crank, our muscle car replacement cam, 906 heads with big valves, harden exhaust seats, 9.3 compression, stock rockers, 750 carb, intake was a stock replacement dual plane from Mopar. Just a great engine. Yes we tuned it after the cam run in and rings seated. We did not try to tune every last amount out of it, it going in a restored car for show and a little street driving. The customer wanted it broke in and a safe tune on it. The BSFC is were our winter fuel has been for this compression and the water temp was were we like it , oil temp was important also. Hope this answers your questions, thanks Pete
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394358
03/03/13 12:34 PM
03/03/13 12:34 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I grew up on a 383 in my 69 Sport Satellite. I sprayed it, beat it, blew head gaskets, broke rings, broke piston skirts and you name it.I couldnt kill it. The 383 is a great little piece, and as you and I know, with the right selection of parts, as you have done, you got a great engine. The customer should be thrilled. They are a lot like a 318, parts selection and care to not overbuild them is critical. Nice little piece.
and yes, tuning on this crappy gas we have is aweful.
RIP Monte Smith
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394359
03/03/13 01:42 PM
03/03/13 01:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's a lot o HP for what amounts to an actual stock rebuild ... except for the cam and the head work and headers for the extra 70hp from stock rating ... oh and the head and shoulders above factory machine work too.
Re: 383 Magnum [Re: JohnRR] #1394360
03/03/13 03:16 PM
03/03/13 03:16 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I am curious about the head work. After the big valves went in was the short turn dressed up? Great little engine there. Can you tell us more about the camshaft?
Re: 383 Magnum [Re: PETE@BESTMACHINE] #1394361
03/03/13 04:38 PM
03/03/13 04:38 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
What a nice engine, I would guess fuel economy would be great as well. This would be a terrific driver.
Sheldon
Re: 383 Magnum [Re: RUNCHARGER] #1394362
03/10/13 11:09 AM
03/10/13 11:09 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
