Re: 383 Magnum
[Re: joshking440]
#1394353
02/27/13 07:18 PM
02/27/13 07:18 PM
Posts: 3,395 Pa
Hot 340
Pa
That looks like a good engine to raffle off
At least the heads dont leak.
Re: 383 Magnum
[Re: GTX MATT]
#1394357
03/03/13 11:19 AM
03/03/13 11:19 AM
Posts: 399 SouthEast Michigan
PETE@BESTMACHINE
SouthEast Michigan
This Block was fully machined on our CNC block machine, Torque plate honed, our valve job, just like all of our builds. It is 4.290 bore, Diamond shelf stock pistons, eagle rods, stock crank, our muscle car replacement cam, 906 heads with big valves, harden exhaust seats, 9.3 compression, stock rockers, 750 carb, intake was a stock replacement dual plane from Mopar. Just a great engine. Yes we tuned it after the cam run in and rings seated. We did not try to tune every last amount out of it, it going in a restored car for show and a little street driving. The customer wanted it broke in and a safe tune on it. The BSFC is were our winter fuel has been for this compression and the water temp was were we like it , oil temp was important also. Hope this answers your questions, thanks Pete
Re: 383 Magnum
[Re: PETE@BESTMACHINE]
#1394358
03/03/13 12:34 PM
03/03/13 12:34 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I grew up on a 383 in my 69 Sport Satellite. I sprayed it, beat it, blew head gaskets, broke rings, broke piston skirts and you name it.I couldnt kill it. The 383 is a great little piece, and as you and I know, with the right selection of parts, as you have done, you got a great engine. The customer should be thrilled. They are a lot like a 318, parts selection and care to not overbuild them is critical. Nice little piece. and yes, tuning on this crappy gas we have is aweful.
RIP Monte Smith
Re: 383 Magnum
#1394359
03/03/13 01:42 PM
03/03/13 01:42 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
That's a lot o HP for what amounts to an actual stock rebuild ... except for the cam and the head work and headers for the extra 70hp from stock rating ... oh and the head and shoulders above factory machine work too.
