Re: Trunk extentions
[Re: 300_dup5]
#1394054
02/27/13 02:40 PM
02/27/13 02:40 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Got a picture to toss on here? Every trunk extension I ever saw uses a pinch seem to the trunk floor: (extension) ----||----- (trunk)
You have an overlap joint? If that's so, it doesn't really matter, and I'd pick whichever way fitted up better. I'm sure someone on here could put up a trunk picture if they just notice the thread.
EDIT: after looking at the parts on AMD, I would guess the extensions go under the trunk floor. But I stress it's a guess.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: 300_dup5]
#1394056
02/28/13 09:36 PM
02/28/13 09:36 PM
Posts: 9,847 MI, usa
dvw
MI, usa
Ya I think your right they go under, that way they run 90 degrees top to bottom, and they slide in the 3 notches , The floor pan has a nice smooth lip on top instead of a seam if they where attached to the side, The trunk floor etc was already taken out when I picked this car up.
The factory pan is one piece. Take a look. Though I patched these it was only the front 6"-8". Doug
