Trunk extentions #1394052
02/26/13 07:25 PM
02/26/13 07:25 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Hi I,m installing a new AMD trunk pan and extentions in my 65 Satellite do the extentions go on the inside or outside of floor pan. Thanks in advance
Re: Trunk extentions [Re: 300_dup5] #1394053
02/27/13 02:34 PM
02/27/13 02:34 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Nobody install trunk pans?
Re: Trunk extentions [Re: 300_dup5] #1394054
02/27/13 02:40 PM
02/27/13 02:40 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Got a picture to toss on here? Every trunk extension I ever saw uses a pinch seem to the trunk floor:
(extension) ----||----- (trunk)
You have an overlap joint? If that's so, it doesn't really matter, and I'd pick whichever way fitted up better. I'm sure someone on here could put up a trunk picture if they just notice the thread.
EDIT: after looking at the parts on AMD, I would guess the extensions go under the trunk floor. But I stress it's a guess.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Trunk extentions [Re: VincentVega] #1394055
02/27/13 07:02 PM
02/27/13 07:02 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Ya I think your right they go under, that way they run 90 degrees top to bottom, and they slide in the 3 notches , The floor pan has a nice smooth lip on top instead of a seam if they where attached to the side, The trunk floor etc was already taken out when I picked this car up.
Re: Trunk extentions [Re: 300_dup5] #1394056
02/28/13 09:36 PM
02/28/13 09:36 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The factory pan is one piece. Take a look. Though I patched these it was only the front 6"-8".
Doug
Re: Trunk extentions [Re: dvw] #1394057
03/02/13 07:58 AM
03/02/13 07:58 AM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Thanks Doug, I see the 3 notches on the originals, Ya the new AMD ones go under to create the slight angle outward as your pic. Cheers
