600hp Max Wedge? #1393119
02/24/13 09:59 PM
02/24/13 09:59 PM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Just asking a theoretical question here.
Would it be possible to make 600hp with an engine running an original style MW crossram intake with AFB carbs and MW cast exhaust manifolds? If so, what would it take as far as the build goes? Bore, stroke, compression, cam? For the exercise, the engine would have to look stock appearing, so either cast iron MW heads or maybe 440Source heads.
Just throwing the question out there, not directed at anyone in particular. Any opinions are welcome.
Re: 600hp Max Wedge? [Re: slantman] #1393120
02/24/13 10:22 PM
02/24/13 10:22 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
The original engine in our car was a Ray Barton 493 with a Bullet 313-321-06 roller, 12-1 compression, stock max wedge heads, stock 63 crossram with 750 Eddy's that was dyno'd at Ray's (with headers) at 614 HP, 627 lb-ft of torque. It can be done with other combos. We are making about 720 hp now, but went with 440-1 heads and the 440-25 intake.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 600hp Max Wedge? [Re: slantman] #1393121
02/24/13 10:22 PM
02/24/13 10:22 PM
AndyF Offline
AndyF  Offline
Re: 600hp Max Wedge? [Re: AndyF] #1393122
02/24/13 10:40 PM
02/24/13 10:40 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Your goal would be much eaiser if you'd run headers instead of the stock exhaust manifolds, I have no experience with them, but do know they will not flow near as well as a good set of headers,you can make the heads your cobsidering work, although neither would be my choice.
Re: 600hp Max Wedge? [Re: wyoming] #1393123
02/25/13 12:09 AM
02/25/13 12:09 AM
fullmetaljacket Offline
Have you'll looked lately at what a fellow out here in New York has done with stock MW exhaust manifolds running in the F.A.S.T class?
Re: 600hp Max Wedge? [Re: fullmetaljacket] #1393124
02/25/13 12:46 AM
02/25/13 12:46 AM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Theres a local guy here in New Milford CT running a stock appearing Max Wedge stroker. Its 500ish cubes, 440 Source SuperStealths, stock looking cross ram, and stock max wedge exhaust manifolds. He's in the neighborhood of the low 700s if I remember correctly. I will see him again soon since cruising season will be starting
His name's Ed, not sure if anyone knows him.
Re: 600hp Max Wedge? [Re: GTX MATT] #1393125
02/25/13 01:13 AM
02/25/13 01:13 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I may be wrong, maybe the stock exhaust can be better than I thought, are they extrude porting these?Like I said I have never ran any that have been on the track or dyno.
Re: 600hp Max Wedge? [Re: GTX MATT] #1393126
02/25/13 01:42 AM
02/25/13 01:42 AM
Yes that's him. Big Ed he goes by. That Maxie is a F.A.S.T Taxi.
Re: 600hp Max Wedge? [Re: GTX MATT] #1393127
02/25/13 09:02 AM
02/25/13 09:02 AM
ny
greenmcode Offline
greenmcode  Offline
ny
Ed is from N.Y. he run's the 63 maxie in F.A.S.T. if
i remember he was pushing in the 800hp range..stock
exhaust manifolds..The heads are steel stock ported..
Re: 600hp Max Wedge? [Re: greenmcode] #1393128
02/25/13 11:55 AM
02/25/13 11:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That would be Ed cooks FAST black 63 Maxie. I have seen him run 10.30's with it. Here is a cool photo he made up with his cars on it. Ron
Re: 600hp Max Wedge? [Re: 383man] #1393129
02/25/13 02:57 PM
02/25/13 02:57 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
10.30's on a set of G70-14 repo bias-ply tires.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: 600hp Max Wedge? [Re: DaveDudek] #1393130
02/25/13 03:45 PM
02/25/13 03:45 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Yes it is possible.
In fact I think you can make the 600hp real easy and still have it very user freidly!
Mine made 805hp using all stock parts modifed. Only issues I have incountered have beed cracks in the heads. Its been together for three seasons. Motor was built by Mike at HP Motors. Will run 10.50's in the heat and 10.30's in the Fall.
But Exhaust manifolds where untouched the last project did not see much gaines in honing them so I saved $600.00
Ed
Re: 600hp Max Wedge? [Re: XXHEMI] #1393131
02/25/13 07:38 PM
02/25/13 07:38 PM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Thanks for all the replies, especially from Ed. Nice to hear it from the horse's mouth, so to speak.
Re: 600hp Max Wedge? [Re: slantman] #1393132
02/25/13 07:46 PM
02/25/13 07:46 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Thats impressive, Ed what kind a MPH are you turning? Wouldnt think the 60' can be real good on those tires? Are those times with full exhaust? Can you share anymore details on the engine?
Re: 600hp Max Wedge? [Re: XXHEMI] #1393133
02/25/13 10:12 PM
02/25/13 10:12 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Yes it is possible.
Ed
Thats a great shot of your car in action Ed...awesome!
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: 600hp Max Wedge? [Re: wyoming] #1393134
02/25/13 11:41 PM
02/25/13 11:41 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Car goes between 131 and 133mph. Should be faster I am missing something just have not figured it out yet? I dont now if the short tire is holding me back? Best sixty is 1.56 but mostly around a 1.60-1.65 depending on the track.
Motor is 540ci 286 heads flow around 320. Intake was heavly modified and lots of compression 15.1. Big solid roller and full exhaust.
The whole package looks factory stock.
Re: 600hp Max Wedge? [Re: XXHEMI] #1393135
02/26/13 10:00 AM
02/26/13 10:00 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
what gears in the rear?
