Re: 600hp Max Wedge?
[Re: slantman]
#1393120
02/24/13 10:22 PM
02/24/13 10:22 PM
Posts: 1,443 Maryland
Dads426
Maryland
The original engine in our car was a Ray Barton 493 with a Bullet 313-321-06 roller, 12-1 compression, stock max wedge heads, stock 63 crossram with 750 Eddy's that was dyno'd at Ray's (with headers) at 614 HP, 627 lb-ft of torque. It can be done with other combos. We are making about 720 hp now, but went with 440-1 heads and the 440-25 intake.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: fullmetaljacket]
#1393124
02/25/13 12:46 AM
02/25/13 12:46 AM
Posts: 5,163 CT
GTX MATT
CT
Theres a local guy here in New Milford CT running a stock appearing Max Wedge stroker. Its 500ish cubes, 440 Source SuperStealths, stock looking cross ram, and stock max wedge exhaust manifolds. He's in the neighborhood of the low 700s if I remember correctly. I will see him again soon since cruising season will be starting His name's Ed, not sure if anyone knows him.
[Re: GTX MATT]
#1393127
02/25/13 09:02 AM
02/25/13 09:02 AM
Posts: 518 ny
greenmcode
ny
Ed is from N.Y. he run's the 63 maxie in F.A.S.T. if i remember he was pushing in the 800hp range..stock exhaust manifolds..The heads are steel stock ported..
[Re: 383man]
#1393129
02/25/13 02:57 PM
02/25/13 02:57 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
10.30's on a set of G70-14 repo bias-ply tires.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: wyoming]
#1393134
02/25/13 11:41 PM
02/25/13 11:41 PM
Posts: 731 NY
XXHEMI
NY
Thats impressive, Ed what kind a MPH are you turning? Wouldnt think the 60' can be real good on those tires? Are those times with full exhaust? Can you share anymore details on the engine?
Car goes between 131 and 133mph. Should be faster I am missing something just have not figured it out yet? I dont now if the short tire is holding me back? Best sixty is 1.56 but mostly around a 1.60-1.65 depending on the track.
Motor is 540ci 286 heads flow around 320. Intake was heavly modified and lots of compression 15.1. Big solid roller and full exhaust. The whole package looks factory stock.
