Page 1 of 3 1 2 3
one more about B block intakes #1384998
02/10/13 08:51 PM
02/10/13 08:51 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Eddy performer, DP4B and MP P4532060
I know, Performer is a fairly stock replacement ( some ppl says a tad better some ppl says the same ).
Also know the DP4B is fairly similar on performance than the Performer RPM as far I have read.
but what about the P4532060 ? it looks pretty much similar to the DP4B! but stock coil location, and choke coil provision.
http://www.ebay.com/itm/MOPAR-PERFORMANC...406&vxp=mtr
Re: one more about B block intakes [Re: NachoRT74] #1384999
02/10/13 09:06 PM
02/10/13 09:06 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I believe the new part number for that manifold is P4529117. I have one of each of the Eddy Performer and the DP4B, I was going to install them on my '66 Chrysler, but the A/C bracket would not clear the front runners. The Mopar one is designed exactly like the stock cast iron one, and would be a perfect fit. I have never seen any numbers on any power increase / decrease with the Mopar one.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: one more about B block intakes [Re: NachoRT74] #1385000
02/10/13 09:08 PM
02/10/13 09:08 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I've heard the Performer is just an aluminum clone of the stock intake? Right? Wrong? I thought it might be a way to shed a couple pounds. Always running through scenarios in my head...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: one more about B block intakes [Re: bschargerse] #1385001
02/11/13 01:24 AM
02/11/13 01:24 AM
Valencia, España
Valencia, España
good to know thanks!
the DP4B claims to be pretty much similar to the Performer RPM on a test made by a magazine
Re: one more about B block intakes [Re: OhioMopar] #1385002
02/11/13 01:26 AM
02/11/13 01:26 AM
Valencia, España
Valencia, España
supposelly, HOWEVER is not the "perfect" clone. Is a tad higher ( maybe 3/8" ), so should make longer runners, so, some difference on performance maybe.
Re: one more about B block intakes [Re: NachoRT74] #1385003
02/11/13 03:59 AM
02/11/13 03:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you have stock heads, the DP4B is a great intake. Once you move from ported stock heads to aftermarket heads you start to out flow the DP4B. I would run that intake, just not with aftermarket heads. OOTB unported 440source or edelbrock rpm heads would be it's limit, and only then with a mild cam.
Re: one more about B block intakes [Re: NachoRT74] #1385004
02/11/13 09:33 AM
02/11/13 09:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have a link to that article , I'm finding that hard to believe.
Re: one more about B block intakes [Re: JohnRR] #1385005
02/11/13 10:22 AM
02/11/13 10:22 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Re: one more about B block intakes [Re: Ronnman] #1385006
02/11/13 11:51 AM
02/11/13 11:51 AM
Valencia, España
Valencia, España
Re: one more about B block intakes [Re: NachoRT74] #1385007
02/11/13 12:30 PM
02/11/13 12:30 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The first time I looked at a perfromer 383, I thought Edelbrock had taken a stock 383 manifold and flipped it 180 degress back to front
The old DP4B was a great manifold for a mildly warm 383; better than a performer but probably not up to the current (much taller) Performer RPM. What I've seen is the aluminum castings back then are inconsistent, some are fine but otheres are soft, esy to strip and the aluminum is 'chalky'. The DP4B I think is more on Par with the Weiand dual plane but both are a step up from the performar 383. On a 4 speed car with 3.91 and up gears I generally prefer the Holley street dominator single plane. It's softer down low but a tad better than even the RPM up top.
Performer < DP4B = Weiand Action < Performer RPM = Holley Street Dominator.
WIZE
In Car:
Re: one more about B block intakes [Re: NachoRT74] #1385008
02/11/13 12:33 PM
02/11/13 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks , very surprising results. It does show how bad stock iron heads really are, I can't believe they built that engine up like that then stuck stock iron heads on it.
Re: one more about B block intakes [Re: Streetwize] #1385009
02/11/13 12:37 PM
02/11/13 12:37 PM
Valencia, España
Valencia, España
mmm... would like your opinions about the MP dual plane piece.... IT LOOKS fairly "the same" than the DP4B
about the Holley SD, Id' like to think the Eddy Street Master was pretty much the same, but on an earlier thread I posted maybe two weeks ago, seems wasn't on that way, being the eddy a POS ( by posters opinions )
Re: one more about B block intakes [Re: NachoRT74] #1385010
02/11/13 01:53 PM
02/11/13 01:53 PM
dogdays Offline
dogdays  Offline
Nacho, have you seen the film, Nacho Libre? You'll either laugh or gag.....Kinda reminds me of Napoleon Dynamite with a fake Spanish accent.
The Holley Street Dominator is well known for being a great RB intake, it's not as great on the B or LA motors, nevertheless it's a heck of a lot better than a Streetmaster for any of the above. The Streetmaster was superceded by the Performer, so you know what its target was.
IIRC the Perf RPM is the third best, the Torker 383 is better and cheap on the used market, and the TM-6 is tops.
If you're building bigger than a 451, I'd look for the TM-6 (part of the Tarantula family) and settle for a Torker383. I got my Torker383 for $50, and plan to use it on my long-term stroker 451.
I am talking about intakes from the "normal" manufacturers, there may be an Indy or other like specialized intake that I don't know.
R.
Re: one more about B block intakes [Re: dogdays] #1385011
02/11/13 03:31 PM
02/11/13 03:31 PM
Valencia, España
Valencia, España
No, but I have laugh with you guys from USA with comparisions LOL
as far the build... you know my build, 400 stroked to 3.75 with 4.362 bore---> 448 ( 451 wannabe )
I'm just looking for another intake options beside the Performer, which is the one I actually have... and you know my conditions. Stockish look and locations. Has been told the DP4B is one of the best, but doesn't meet my requirements with the coil and manifold choke locations. The MP uses the earlier choke setup and square bore carb, but I think would live with that using the earlier choke coil and carb adaptor... would need to use a longer choke rod of course using the plate adaptor unless I remove the backelite plate TQs uses. And would search the way to add the electric assistant choke system, from laters models
the Holley SD is another option ( being the Streetmaster has been claimed to be not as good ) but aren't supposselly the single planes able to loose bottom end power ?
Re: one more about B block intakes [Re: NachoRT74] #1385012
02/11/13 03:45 PM
02/11/13 03:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm just looking for another intake options beside the Performer... and you know my conditions. Stock look and locations. Has been told the DP4B is one of the best, but doesn't meet my requirements with the coil and manifold choke locations. The MP uses the earlier choke setup and square bore carb, but I think would live with that using the earlier choke coil and carb adaptor... would need to use a longer choke rod of course. And would search the way to add the electric assistant choke system, from laters models
The M1 dual plane uses the 70 up choke configuration.
You can add the missing stuff to the DP4B if you're handy with a Tig welder.
Re: one more about B block intakes [Re: JohnRR] #1385013
02/11/13 03:52 PM
02/11/13 03:52 PM
Valencia, España
Valencia, España
which one is the M1 dual plane ? If this:
is the P4529117 I'm asking if is similar in performance to the DP4B acclaimed as one of the best ( althought I asked first for another PN which looks to be superseded by this ) and shows the earlier choke setup
Re: one more about B block intakes [Re: NachoRT74] #1385014
02/11/13 04:02 PM
02/11/13 04:02 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Since you're building a 451-ish stroker low deck, I'd try to find a performer RPM for a heavier tighter stall, higher geared combo or a Street Dominator for a lighter, more stall, deeper geared combo. A SD doesn't really 'look' stock (single plane) but it does have a near stock carb height, An RPM is much taller than stock and would need a drop base air cleaner. Given your parameters, the Performar may be your best bet....especially since you already have it.
The performer really isn't a "bad" piece, it's just not substantially better than stock. Cam selection is also a critical piece for 451's in order to get the most out of them.
WIZE
In Car:
Re: one more about B block intakes [Re: Streetwize] #1385015
02/11/13 04:12 PM
02/11/13 04:12 PM
dogdays Offline
dogdays  Offline
Wize has a point...You aren't dead yet, so you can start out with the Performer and then decide on where to go from there. People change engine combinations all the time.
My $500 ford truck with the 400 runs quite well with the Performer on it, I won't be buying anything different for it as it does everything I need and there aren't too many intakes for that engine anyway. So maybe you use what you have and step up at a later date if you wish.
R.
Re: one more about B block intakes [Re: Streetwize] #1385016
02/11/13 04:19 PM
02/11/13 04:19 PM
Valencia, España
Valencia, España
engine is already running since one year ago with Performer intake I bought cheap ( US$60 ) on a Crower 282 cam. MP 175K TC, 3.55 SG gears with 255/60-15 tires
Performer is definitelly higher than the stock iron. Already prooved that. Had to cut down a little bit the front coil location to be able to fit the rear AC Compressor bracket what attachs to this point. So SOME DIFFERENCE must have with the stock on performance.
Just looking forward to another options
Holley SD is not really stock look but on the first view with everything on stock location WILL LOOK stock, down the stock air cleaner, carburator and behind the AC RV2 compressor. Just the vacuum provision will make a BIG difference, being on the passenger side. The Streetmaster beats the SD on this with the EGR and vacuum provisions location... Shame by all ppl here the Streetmaster looks to be a POS.
I don't care EGR system since Venezuelan assemblied cars didn't got EGR system... at least not my car.
I'm not saying am not satisfied with the Performer, just watching for a future upgrade and note the differences.
For me, the Street Dominator is a winner to me, ( even I like more the Streetmaster look ) but wondering about this on a driver, usually low RMP car, where suposselly Single planes loose bottom end power. The magazine test prooves that. Thats why I'm looking for a dual plane option. WITH STOCK LOCATIONS ( choke and coil ). If were spread bore, even better.
Re: one more about B block intakes [Re: NachoRT74] #1385017
02/11/13 04:46 PM
02/11/13 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that is the M1 dual plane, appears to be a carbon copy of the 70 cast iron 4bbl. With some welding on the drivers side of the intake you could turn it into a spreadbore if you want to do that way .
Page 1 of 3 1 2 3
