70 cuda rear license plate frame color #1384968
02/10/13 07:49 PM
02/10/13 07:49 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
The rear license plate frame on my cuda was painted flat black , is this correct?
Re: 70 cuda rear license plate frame color [Re: cudachas] #1384969
02/10/13 08:55 PM
02/10/13 08:55 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
It was unpainted, it was bare metal finished in some kind of no longer available galvanizing. Someone on the board will chime in with a more accuarate description. But it was definitely unpainted.
Re: 70 cuda rear license plate frame color [Re: cudachas] #1384970
02/10/13 08:57 PM
02/10/13 08:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Re: 70 cuda rear license plate frame color [Re: burdar] #1384971
02/10/13 09:05 PM
02/10/13 09:05 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Thanks for the quick reply. I had a felling they were not painted. Will try to find something close to galvanize to paint it with. Thanks again,Charlie.
Re: 70 cuda rear license plate frame color [Re: cudachas] #1384972
02/10/13 09:11 PM
02/10/13 09:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'd try used a paint stripper on it. You might find that the original galvanizing is still in good shape...if it wasn't blasted off. You could coat it with RPM or spray a clear on it after that.
Re: 70 cuda rear license plate frame color [Re: burdar] #1384973
02/10/13 09:49 PM
02/10/13 09:49 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Re: 70 cuda rear license plate frame color [Re: burdar] #1384974
02/11/13 12:20 PM
02/11/13 12:20 PM
m46rat Offline
m46rat  Offline
If you use a paint stripper you will also remove or wreck the original galvanizing.
Re: 70 cuda rear license plate frame color [Re: m46rat] #1384975
02/11/13 01:14 PM
02/11/13 01:14 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I have used aerosol paint stripper on all kinds of finishes and the original plating never got hurt......probably not near as aggressive as the really good strippers.....Um, I mean, paint removers...
Re: 70 cuda rear license plate frame color [Re: FJ5_Fish] #1384976
02/11/13 02:07 PM
02/11/13 02:07 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
A couple paint removers I've used trying to preserve the underlying finish is Castrol Super Clean and brake fluid with decent results. How aggressive the stripper needs to be is very dependent on the material it was painted with.
But, If the original galvanized finish is toast.
You can get reasonably close with a paint finish called hammerite. I think it's a duplicolor rattle can spray (maybe krylon ???)
FYI, It takes some practice to obtain a mottled look. your mileage may vary.
Keep in mind if your going OE don't bother, as your not going to fool anyone it's correct. But to the casual observer it'll pass with flying colors.
Re: 70 cuda rear license plate frame color [Re: gtx6970] #1384977
02/12/13 08:16 PM
02/12/13 08:16 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Thanks everyone. I glass beaded the frame already so it will have to be painted. Anyone use the galvanize paint from eastwood's?
Re: 70 cuda rear license plate frame color [Re: cudachas] #1384978
02/12/13 08:51 PM
02/12/13 08:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I have, don't look nothing like galvanized.
I think Eastwood Tank Tone looks better than their galvanized paint does. Try it I think you will like it, Tank Tone, but it don't look like galvanizing either.
Re: 70 cuda rear license plate frame color [Re: Challenger 1] #1384979
02/13/13 10:30 PM
02/13/13 10:30 PM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
The closest thing I have come up with that does look like galvanized metal is a technique called paint marbleing. I use silver paint (preferably Chrome type paint that you would use to paint the inside of light housingings for the reflective backbround. What you do is clean the metal really well then spray the chrome paint (heavy coat to the point of running off the part) Then with a piece of newspaper that you have crumpled up you daub the paint all over the part. Don't over do it Practice makes perfect. When you are done what you end up with is a shading of the chrome paint that resembles galvanize. You get hi and low sheen with this method. If you want to dull the finish a little more you then hit it with a semi clear coat to seal it. I've used this to the point of having the EXPERTS ask where I had my galvanizing done. This works really well on the inside covers to the side marker retainers as well
Re: 70 cuda rear license plate frame color [Re: LemonTwiist] #1384980
02/14/13 02:09 AM
02/14/13 02:09 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Both the above techniques look great.
Here's how they appeared NOS, this one being a B-body
Re: 70 cuda rear license plate frame color [Re: mccannix] #1384981
02/14/13 02:18 AM
02/14/13 02:18 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
back side..
Re: 70 cuda rear license plate frame color [Re: LemonTwiist] #1384982
02/14/13 11:36 AM
02/14/13 11:36 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
wow LemonTwist - that looks real good for a home done job!
Re: 70 cuda rear license plate frame color [Re: shakerjoe] #1384983
02/14/13 01:06 PM
02/14/13 01:06 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
....though I just bought a good original galvanized pce and cleaned it up.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 cuda rear license plate frame color [Re: DPelletier] #1384984
02/16/13 06:59 PM
02/16/13 06:59 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Thanks, will practice before I try. It does look good, nice job.
Re: 70 cuda rear license plate frame color [Re: shakerjoe] #1384985
02/16/13 07:19 PM
02/16/13 07:19 PM
SE Pa.
LimeliteAero Offline
SE Pa.
That look much better than good....that looks AMAZING !!!!!!
Re: 70 cuda rear license plate frame color [Re: LimeliteAero] #1384986
02/16/13 07:41 PM
02/16/13 07:41 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Here is a one with original stamps on the backside i found a while ago.. Bracket was also galvanized.
