Re: 70 cuda rear license plate frame color
[Re: cudachas]
#1384970
02/10/13 08:57 PM
02/10/13 08:57 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#1384973
02/10/13 09:49 PM
02/10/13 09:49 PM
Posts: 2,309 South, FL
cudaized
South, FL
I'd try used a paint stripper on it. You might find that the original galvanizing is still in good shape...
[Re: burdar]
#1384974
02/11/13 12:20 PM
02/11/13 12:20 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
I'd try used a paint stripper on it. You might find that the original galvanizing is still in good shape...if it wasn't blasted off. You could coat it with RPM or spray a clear on it after that.
If you use a paint stripper you will also remove or wreck the original galvanizing.
[Re: LemonTwiist]
#1384982
02/14/13 11:36 AM
02/14/13 11:36 AM
Posts: 3,000 Long Island, NY
shakerjoe
Long Island, NY
The closest thing I have come up with that does look like galvanized metal is a technique called paint marbleing. I use silver paint (preferably Chrome type paint that you would use to paint the inside of light housingings for the reflective backbround. What you do is clean the metal really well then spray the chrome paint (heavy coat to the point of running off the part) Then with a piece of newspaper that you have crumpled up you daub the paint all over the part. Don't over do it Practice makes perfect. When you are done what you end up with is a shading of the chrome paint that resembles galvanize. You get hi and low sheen with this method. If you want to dull the finish a little more you then hit it with a semi clear coat to seal it. I've used this to the point of having the EXPERTS ask where I had my galvanizing done. This works really well on the inside covers to the side marker retainers as well
wow LemonTwist - that looks real good for a home done job!
[Re: shakerjoe]
#1384985
02/16/13 07:19 PM
02/16/13 07:19 PM
Posts: 6,584 SE Pa.
LimeliteAero
SE Pa.
That look much better than good....that looks AMAZING !!!!!!
[Re: LimeliteAero]
#1384986
02/16/13 07:41 PM
02/16/13 07:41 PM
Posts: 1,552 Sweden
71redcuda
Sweden
Here is a one with original stamps on the backside i found a while ago.. Bracket was also galvanized.
