Re: Header Bolts
[Re: dhkennedy]
#1383083
02/08/13 10:42 AM
02/08/13 10:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Best advise for headers, leave as many mani studs in as you can, when you use header bolts use the long ones w/ some sealer, use good gaskets and do not crank the snot out of the bolts. As for wrap, it probably does keep temps down but it seems to quickly rust the headers out. I've never had an issue w/ excess heat under the hood. Just open the hood and in 5-10 minutes you're good. Manifolds hold the heat 20x as long as headers. I have no idea about the product, however I'd never pay $100 for a set of bolts, but then again I'd never pay $800 for a set of headers either.
Re: Header Bolts
[Re: screamindriver]
#1383086
02/08/13 03:19 PM
02/08/13 03:19 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I've used Mr Gasket ultraseals with good results...
Agreed...
Re: Header Bolts
[Re: RSNOMO]
#1383087
02/08/13 04:01 PM
02/08/13 04:01 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I have ceramic coated headers on my shorty. I heat or lack of it is remarkable. They really help the heat to go out the pipes and not radiate into the engine compartment..
I am truckless..
Re: Header Bolts
[Re: mikemee1331]
#1383090
02/09/13 07:34 AM
02/09/13 07:34 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I use studs on my aluminum headed 440.They have been on now for 4 years and no problems.My kid runs them on his iron head 413 also.We both run Mr Gasket Ultras.Ive even pulled the headers and reused them and no leaks.Only place I use bolts are where studs wont fit.Rocky
Chrysler Firepower
Re: Header Bolts
[Re: 71birdJ68]
#1383091
02/09/13 10:27 AM
02/09/13 10:27 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
""Who makes the best gaskets?""
I don't know about the best, but I replaced my TTi header gaskets with the Percy's Seal 4 Good and my leaks were fixed. The attached shows where the TTI gaskets (black) needed to be opened up (340) and the Percy's were already good. You can get the Percy's at your local Autozone.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Header Bolts
[Re: YO7_A66]
#1383092
02/09/13 03:55 PM
02/09/13 03:55 PM
therocks
Niles , Ohio
I ran a set on my TTIs.they leaked like no gasket at all.Never again.I do use the coppers from Summit on my collectors.Rocky
Chrysler Firepower
