Header Bolts #1383079
02/07/13 11:09 AM
02/07/13 11:09 AM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Anybody have any experience with these locking bolts for headers? Are they worth the almost $100 they cost. Alum.heads, TTIs. And header wrap, does it really keep the under hood temps down?
Re: Header Bolts [Re: 71birdJ68] #1383080
02/07/13 11:38 PM
02/07/13 11:38 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Are you talking about the stage 8 fasteners ??? Have'nt priced them in a while but they work great...And the header wrap does keep the underhood temps down but...Some wraps are tough to keep clean, and all wraps will prematurely rust the headers...
Re: Header Bolts [Re: screamindriver] #1383081
02/08/13 12:39 AM
02/08/13 12:39 AM
Morristown Tn.
Morristown Tn.
Yes I was looking at the stage 8 bolts. kinda high. These headers will be ceramic coated, will they still rust with the header wrap. I have a high dollar paint job and don't want the headers cooking the paint on the hood. Its a air grabber so I can't put a insulation pad on it.
Re: Header Bolts [Re: 71birdJ68] #1383082
02/08/13 03:03 AM
02/08/13 03:03 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
I have the Stage8 on Ceramic Headers and I have had no problems at all. I use Permatex thread sealer on them also.I would not wrap the headers, ruined a set in 14 months. Being in a 440 in a D100 the heater hose lays about 1 inch from pipes and has not melted. I run around 3800 rpm at 60, 4.56 rear with 8.75x16.5 so everything gets heat under the hood.Summit carries the Stage8 for about $50 so just double check witch you need, 3/4 or 1".
Re: Header Bolts [Re: dhkennedy] #1383083
02/08/13 10:42 AM
02/08/13 10:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Best advise for headers, leave as many mani studs in as you can, when you use header bolts use the long ones w/ some sealer, use good gaskets and do not crank the snot out of the bolts. As for wrap, it probably does keep temps down but it seems to quickly rust the headers out. I've never had an issue w/ excess heat under the hood. Just open the hood and in 5-10 minutes you're good. Manifolds hold the heat 20x as long as headers. I have no idea about the product, however I'd never pay $100 for a set of bolts, but then again I'd never pay $800 for a set of headers either.
Coming soon!!!!
Re: Header Bolts [Re: Mr.Yuck] #1383084
02/08/13 10:50 AM
02/08/13 10:50 AM
Morristown Tn.
Morristown Tn.
This is an Alum headed Hemi, so waters not an issue.I just didn't want to have to retighten them all the time. Who makes the best gaskets?
Re: Header Bolts [Re: 71birdJ68] #1383085
02/08/13 02:49 PM
02/08/13 02:49 PM
Harrisburg, Pa.
Harrisburg, Pa.
Best gasket set would be the remflex brand... link In the normal price range/supplier category I've used Mr Gasket ultraseals with good results...
Re: Header Bolts [Re: screamindriver] #1383086
02/08/13 03:19 PM
02/08/13 03:19 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Agreed...
Re: Header Bolts [Re: RSNOMO] #1383087
02/08/13 04:01 PM
02/08/13 04:01 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have ceramic coated headers on my shorty. I heat or lack of it is remarkable. They really help the heat to go out the pipes and not radiate into the engine compartment..
I am truckless..
Re: Header Bolts [Re: 71birdJ68] #1383088
02/08/13 05:54 PM
02/08/13 05:54 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Agree with others. Ceramic coating will help keep heat down - no wrap required. I have header pipes very close to (what was) fresh paint and was concerned about possible bubbling but it never became an issue.
I prefer studs to bolts whether coolant is an issue or not and will second the use of Remflex gaskets. They will take care of any surface irregularities.
Re: Header Bolts [Re: 70Duster440] #1383089
02/08/13 07:52 PM
02/08/13 07:52 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and even ceramic coated headers get rust. little annoying dots of it!
Re: Header Bolts [Re: mikemee1331] #1383090
02/09/13 07:34 AM
02/09/13 07:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use studs on my aluminum headed 440.They have been on now for 4 years and no problems.My kid runs them on his iron head 413 also.We both run Mr Gasket Ultras.Ive even pulled the headers and reused them and no leaks.Only place I use bolts are where studs wont fit.Rocky
Chrysler Firepower
Re: Header Bolts [Re: 71birdJ68] #1383091
02/09/13 10:27 AM
02/09/13 10:27 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Who makes the best gaskets?""
I don't know about the best, but I replaced my TTi header gaskets with the Percy's Seal 4 Good and my leaks were fixed. The attached shows where the TTI gaskets (black) needed to be opened up (340) and the Percy's were already good. You can get the Percy's at your local Autozone.
Re: Header Bolts [Re: YO7_A66] #1383092
02/09/13 03:55 PM
02/09/13 03:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran a set on my TTIs.they leaked like no gasket at all.Never again.I do use the coppers from Summit on my collectors.Rocky
Chrysler Firepower
