helppppppppppppppppppp!!!!!! #138021
10/17/08 03:30 PM
10/17/08 03:30 PM
NC USA
71mopardude Offline OP
I don't get it?
I don't get it?
NC USA
whats the best way to get off an over tighten oil filter (small block in an a-body with manifolds) ihave already broken one filter wrench should i rip the metal off and then try to turn the threads off??? what to do ???? thanks
Re: helppppppppppppppppppp!!!!!! [Re: 71mopardude] #138022
10/17/08 03:41 PM
10/17/08 03:41 PM
Just South of The Motor City
limechallenger Offline
try grabbing it with a strip of rubber between the filter and the wrench !
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: helppppppppppppppppppp!!!!!! [Re: limechallenger] #138023
10/17/08 03:45 PM
10/17/08 03:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Drive a long punch through it as close to the base as possible and turn the punch.
Re: helppppppppppppppppppp!!!!!! [Re: MoparforLife] #138024
10/17/08 04:01 PM
10/17/08 04:01 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
And if that don't work, use the punch and a hammer, start tapping it counter clock wise.
Oh... read the directions on the side of the filter next time.
When was the last time you heard of a filter coming off be itself? there is no need to over tighten it.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: helppppppppppppppppppp!!!!!! [Re: HealthServices] #138025
10/17/08 04:04 PM
10/17/08 04:04 PM
NC USA
I don't get it?
I don't get it?
NC USA
lmao im not that stupid its a car i just bought not one that i have worked on before lol but thanks for the advice i will give it a try !!!
Re: helppppppppppppppppppp!!!!!! [Re: HealthServices] #138026
10/17/08 04:04 PM
10/17/08 04:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
take a phillips screw driver in one hand get a hammer in the other, tap it thru then turn it. Let all the oil leak out and into a catch can..the pop another hole and turn, by then it should be loose enough to turn by hand
Re: helppppppppppppppppppp!!!!!! [Re: Mr.Yuck] #138027
10/17/08 04:09 PM
10/17/08 04:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Are you getting the wrench as close to the block as possible?
Re: helppppppppppppppppppp!!!!!! [Re: 71mopardude] #138028
10/17/08 04:14 PM
10/17/08 04:14 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
punch through it and turn, or if it is not too oily, grab some course sandpaper, wrap the filter and use your muscles. Make sure that you add a thin coat of oil to the rubber gasket on the new filter to prevent this....and don;t put it on with a wrench, hand tight is plenty.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: helppppppppppppppppppp!!!!!! [Re: 71mopardude] #138029
10/18/08 02:04 PM
10/18/08 02:04 PM
NC USA
I don't get it?
I don't get it?
NC USA
Got it off!!!!!!!!!!!! took removing the exhaust and putting a long punch through it and an oil filter wrench on it and reefing on both like a mother !!! lol why do ppl do these things????
will post a pic of the mangled filter later just for laughs thanks to all for the help
Re: helppppppppppppppppppp!!!!!! [Re: 71mopardude] #138030
10/18/08 11:57 PM
10/18/08 11:57 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
It's right up there with shops using an air wrench to crank down the lug nuts. "What, they're supposed to be torqued to a certain spec? " Just causes more trouble down the line and there's no need for it...
Re: helppppppppppppppppppp!!!!!! [Re: In_The_Pink] #138031
10/19/08 12:20 AM
10/19/08 12:20 AM
next time, try this trick my dad taught me.
use a belt. wrap a belt around it so it goes thru the buckle and back over itself . make it so when you pull on it, it unwinds. works EVERY TIME
Re: helppppppppppppppppppp!!!!!! #138032
10/20/08 02:25 PM
10/20/08 02:25 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
I have run into oil filters that the belt trick won't work with even with sand paper in between. I have also run into filters that a punch through the body of the filter just rips the can.
In the most subborn cases a large slip joint plier grabing the base usually works and if you can get a purcahse on the base then a cold chisel tangentially on the base will bit in enough to allow you to tap it loose with a hammer.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: helppppppppppppppppppp!!!!!! [Re: dgc333] #138033
10/20/08 02:40 PM
10/20/08 02:40 PM
So Cal
So Cal
We have had cars towed in from the oil change shops with just the oil filter base on. Everything else was tried and failed, nothing left but the base.
I use the cold chisel on the remaining parts and tap it loose with a hammer.
Easy 1 hour labor, 10 minutes work or less after pushing the car onto the rack..
Re: helppppppppppppppppppp!!!!!! [Re: HealthServices] #138034
10/20/08 02:50 PM
10/20/08 02:50 PM
So Cal
So Cal
Oh plus the cost of an oil change, of course I don't get paid for any part of the tow.
Re: helppppppppppppppppppp!!!!!! [Re: HealthServices] #138035
10/20/08 04:06 PM
10/20/08 04:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use 2 filter wrenches together. Extreme cases we have used 2 strap along with a end cup style. When rookies here at work tear off the can I air chisel the base to rotate it around. either way will work one is messier. i've been a dealer tech 26 years,these methods will work.
Doug
Re: helppppppppppppppppppp!!!!!! [Re: 71mopardude] #138036
10/20/08 04:22 PM
10/20/08 04:22 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
At the risk of stating the obvious, the shards from a stabbed filter can be very sharp indeed. Use great care when taking the hammer and chisel to the nothing-left-but-the-base oil filter that got towed into your shop.
DAMHIK
Down to just a blue car now.
