Re: helppppppppppppppppppp!!!!!!
[Re: 71mopardude]
#138028
10/17/08 04:14 PM
10/17/08 04:14 PM
Posts: 752 AZ - The "dry heat" state
71autoxr
punch through it and turn, or if it is not too oily, grab some course sandpaper, wrap the filter and use your muscles. Make sure that you add a thin coat of oil to the rubber gasket on the new filter to prevent this....and don;t put it on with a wrench, hand tight is plenty.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
[Re: In_The_Pink]
#138031
10/19/08 12:20 AM
10/19/08 12:20 AM
next time, try this trick my dad taught me.
use a belt. wrap a belt around it so it goes thru the buckle and back over itself . make it so when you pull on it, it unwinds. works EVERY TIME
[Re: dgc333]
#138033
10/20/08 02:40 PM
10/20/08 02:40 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
We have had cars towed in from the oil change shops with just the oil filter base on. Everything else was tried and failed, nothing left but the base.
I use the cold chisel on the remaining parts and tap it loose with a hammer.
Easy 1 hour labor, 10 minutes work or less after pushing the car onto the rack..
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#138034
10/20/08 02:50 PM
10/20/08 02:50 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Oh plus the cost of an oil change, of course I don't get paid for any part of the tow.
Allen
[Re: 71mopardude]
#138036
10/20/08 04:22 PM
10/20/08 04:22 PM
Posts: 9,312 SoCal
68HemiB
SoCal
At the risk of stating the obvious, the shards from a stabbed filter can be very sharp indeed. Use great care when taking the hammer and chisel to the nothing-left-but-the-base oil filter that got towed into your shop. DAMHIK
Down to just a blue car now.
