Re: where do i find one of these? electrical connection
[Re: JohnRR]
#1379006
01/31/13 01:28 AM
01/31/13 01:28 AM
Posts: 4,179 California
mickm
California
What distributor , that is not a factory mopar connector
i thought it was. when i got the car, it had an accel distributor on it, and this was the connection to it. when i put an MSD in it, i put that connector on for the new distributor.
what does a stock connection look like?
[Re: MoparMarq]
#1379008
01/31/13 01:40 AM
01/31/13 01:40 AM
mickm
California
Can be seen here laying on the distributor hold down clamp.
where would i get that connection? i only have the half that is on the distributor.
[Re: mickm]
#1379009
01/31/13 01:43 AM
01/31/13 01:43 AM
RapidRobert
Add wires to the one you have or use any 2 wire pull apart connector if desired & solder it in or even 2 sets of 2ea male/female bullet connectors, just make sure the polarity is correct (see archives). If you had the correct zigzag OE connector that'd be the best way to go if you had a spare pickup plate/coil/pigtail, just swap it in
[Re: mickm]
#1379010
01/31/13 01:54 AM
01/31/13 01:54 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I've probably got a few of them in garage somewhere, but any Mopar guy near you probably does, too. Any JY with old Mopars in it, is going to have them, too. The harness end is the same as the distributor end, so snip the pigtails off the harnesses of a couple of Mopars and splice 'em into your car.
I've used 'em to add a few electrical items where polarity mattered, cuz the two ends can only go together one way.
[Re: MoparMarq]
#1379011
01/31/13 02:20 AM
01/31/13 02:20 AM
mickm
California
ok, i'll check around. what did the stock connector look like back in 1970? same thing?
[Re: mickm]
#1379012
01/31/13 02:22 AM
01/31/13 02:22 AM
Posts: 192 San Jose, Ca.
dhkennedy
San Jose, Ca.
this is the stock connection to the distributor, (at least i think it is).
where can i find one of these?
Those are old Tamya RC Battery conectors from the mid 80's. I think they are refered to as Molinex(sp) and should be able to get from Radio Shack. They are referd to as Meltfast in the RC trades, 3-5 Amps for 4-6 minutes and their a fire hazzard.
[Re: mickm]
#1379013
01/31/13 02:24 AM
01/31/13 02:24 AM
Posts: 75,026 U.S.S.A.
JohnRR
U.S.S.A.
There was no connector in 70 like that , 70 used a dual point presolite, one lead coming out of the distributor connecting to the negative side of the coil.
[Re: dhkennedy]
#1379015
01/31/13 06:29 PM
01/31/13 06:29 PM
Posts: 1,822 Colorado
denfireguy
Colorado
It is Molex. Unfortunately, not genuine Molex but a knockoff. You can get the genuine article here: http://www.digikey.com/Suppliers/us/Molex.page?lang=en
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: dogdays]
#1379017
02/02/13 06:59 PM
02/02/13 06:59 PM
mickm
California
The stock Mopar electronic distributor connector was basically a two-wire trailer lighting connector but with different colored wires. I bought mine at Wal-Mart.
R.
nice, thanks for the info!
