where do i find one of these? electrical connection #1379004
01/31/13 01:13 AM
01/31/13 01:13 AM
California
mickm Offline OP
mickm  Offline OP
California
this is the stock connection to the distributor, (at least i think it is).
where can i find one of these?
Re: where do i find one of these? electrical connection [Re: mickm] #1379005
01/31/13 01:16 AM
01/31/13 01:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What distributor , that is not a factory mopar connector
Re: where do i find one of these? electrical connection [Re: JohnRR] #1379006
01/31/13 01:28 AM
01/31/13 01:28 AM
California
mickm Offline OP
mickm  Offline OP
California
i thought it was. when i got the car, it had an accel distributor on it, and this was the connection to it. when i put an MSD in it, i put that connector on for the new distributor.
what does a stock connection look like?
Re: where do i find one of these? electrical connection [Re: mickm] #1379007
01/31/13 01:36 AM
01/31/13 01:36 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Can be seen here laying on the distributor hold down clamp.
Re: where do i find one of these? electrical connection [Re: MoparMarq] #1379008
01/31/13 01:40 AM
01/31/13 01:40 AM
California
mickm Offline OP
mickm  Offline OP
California
where would i get that connection? i only have the half that is on the distributor.
Re: where do i find one of these? electrical connection [Re: mickm] #1379009
01/31/13 01:43 AM
01/31/13 01:43 AM
Add wires to the one you have or use any 2 wire pull apart connector if desired & solder it in or even 2 sets of 2ea male/female bullet connectors, just make sure the polarity is correct (see archives). If you had the correct zigzag OE connector that'd be the best way to go if you had a spare pickup plate/coil/pigtail, just swap it in
Re: where do i find one of these? electrical connection [Re: mickm] #1379010
01/31/13 01:54 AM
01/31/13 01:54 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I've probably got a few of them in garage somewhere, but any Mopar guy near you probably does, too. Any JY with old Mopars in it, is going to have them, too. The harness end is the same as the distributor end, so snip the pigtails off the harnesses of a couple of Mopars and splice 'em into your car.
I've used 'em to add a few electrical items where polarity mattered, cuz the two ends can only go together one way.
Re: where do i find one of these? electrical connection [Re: MoparMarq] #1379011
01/31/13 02:20 AM
01/31/13 02:20 AM
California
mickm Offline OP
mickm  Offline OP
California
ok, i'll check around. what did the stock connector look like back in 1970? same thing?
Re: where do i find one of these? electrical connection [Re: mickm] #1379012
01/31/13 02:22 AM
01/31/13 02:22 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
Those are old Tamya RC Battery conectors from the mid 80's. I think they are refered to as Molinex(sp) and should be able to get from Radio Shack. They are referd to as Meltfast in the RC trades, 3-5 Amps for 4-6 minutes and their a fire hazzard.
Re: where do i find one of these? electrical connection [Re: mickm] #1379013
01/31/13 02:24 AM
01/31/13 02:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There was no connector in 70 like that , 70 used a dual point presolite, one lead coming out of the distributor connecting to the negative side of the coil.
Re: where do i find one of these? electrical connection [Re: JohnRR] #1379014
01/31/13 01:39 PM
01/31/13 01:39 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Local parts store should have the factory style connector as a universal in their electrical section.
Re: where do i find one of these? electrical connection [Re: dhkennedy] #1379015
01/31/13 06:29 PM
01/31/13 06:29 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
It is Molex. Unfortunately, not genuine Molex but a knockoff.
You can get the genuine article here:
http://www.digikey.com/Suppliers/us/Molex.page?lang=en
Re: where do i find one of these? electrical connection [Re: denfireguy] #1379016
01/31/13 06:48 PM
01/31/13 06:48 PM
dogdays Offline
dogdays  Offline
The stock Mopar electronic distributor connector was basically a two-wire trailer lighting connector but with different colored wires. I bought mine at Wal-Mart.
R.
Re: where do i find one of these? electrical connection [Re: dogdays] #1379017
02/02/13 06:59 PM
02/02/13 06:59 PM
California
mickm Offline OP
mickm  Offline OP
California
R.
nice, thanks for the info!
