Re: can a 833 23 splin hold up to over 800fpt & 900hp
[Re: 1000+sbm]
#1377020
01/30/13 07:09 PM
01/30/13 07:09 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
I have been calling around, and so far g focus is the way to go. $4000 for 5sd tranny,, $600 for scatter shield, $200 for shifter, ?$ miscellaneous and feb work.
Make sure you get a good adjustable pressure plate type clutch (aka slipper clutch) to protect those expensive driveline parts. Tim Hyatt of Hyatt Racing can get you set up 440-254-1311
[Re: 1000+sbm]
#1377024
01/31/13 02:03 PM
01/31/13 02:03 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You won't break this one. Available in junkyards everywhere. Depending on the torque rating, 1250-2050 ft/lbs $1000-$4500. Floor pan will need to be cut of course and with 13 gears you may need to work on your shifting game. Kevin
[Re: Twostick]
#1377026
02/01/13 09:32 PM
02/01/13 09:32 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Kevin
And it's unsychronised, bonus!!
[Re: dvw]
#1377029
02/02/13 11:12 AM
02/02/13 11:12 AM
Posts: 3,420 Toronto
mshred
Toronto
I don't dispute anyone's experiences. But how did anyone ever race Pro Stock in the 70s? Be it GM or Chrysler they were coupled to a 833 trans back in the day. Along with inferior clutch technology of that period it's amazing that Ronnie Sox ever finished a race. Just asking, how did they do it? Doug
I have have no doubt that those transmissions were coming out for refresh or being swapped after every event or even possibly every couple of races.
