Page 3 of 3 1 2 3
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: 68shifter] #1377018
01/29/13 10:25 PM
01/29/13 10:25 PM
1000+sbm Offline OP
1000+sbm  Offline OP
i will start calling around. yall have give my a lot of choices, im thinking one of the trannings can be street driven and race at the track.
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: 1000+sbm] #1377019
01/30/13 12:36 PM
01/30/13 12:36 PM
1000+sbm Offline OP
1000+sbm  Offline OP
I have been calling around, and so far g focus is the way to go. $4000 for 5sd tranny,, $600 for scatter shield, $200 for shifter, ?$ miscellaneous and feb work.
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: 1000+sbm] #1377020
01/30/13 07:09 PM
01/30/13 07:09 PM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
Make sure you get a good adjustable pressure plate type clutch (aka slipper clutch) to protect those expensive driveline parts. Tim Hyatt of Hyatt Racing can get you set up 440-254-1311
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: 1000+sbm] #1377021
01/30/13 10:04 PM
01/30/13 10:04 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
In a Duster I exploded 3rd gear in a Liberty slick shifted hemi box a few years back with 225/70 firehawk radials,it prolly only had 400 horse if I was lucky.Was giving a friend a ride that he will never forget,was just about ready to shift into 4th and BANG!!!
Mitch
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: 1000+sbm] #1377022
01/31/13 12:11 AM
01/31/13 12:11 AM
Lawton, MI
Headhunter22 Offline
Lawton, MI
I will chime in, 68shifter posted above. I can give you the lowdown on his car (mostly), 600-650 hp, 3200 lbs, slipper clutch. 20-30 passes on a transmission. I've attached the picture of 3rd that he broke, face plated, cryogenic processed, ..etc.
Has a G-force now. Only broke that once...
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: Headhunter22] #1377023
01/31/13 10:04 AM
01/31/13 10:04 AM
1000+sbm Offline OP
1000+sbm  Offline OP
What was the g force rated at? When the g-force broke was it driver error or ? And how do he like his g-force tranny? When I talk to them yesterday they offer me the 5or 6 sd rated at 1000fpt. Is this the same tranny he have?
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: 1000+sbm] #1377024
01/31/13 02:03 PM
01/31/13 02:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You won't break this one. Available in junkyards everywhere. Depending on the torque rating, 1250-2050 ft/lbs $1000-$4500.
Floor pan will need to be cut of course and with 13 gears you may need to work on your shifting game.
Kevin
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: Twostick] #1377025
02/01/13 09:22 PM
02/01/13 09:22 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That'll double the weight of the car, won't break though
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: Twostick] #1377026
02/01/13 09:32 PM
02/01/13 09:32 PM
Guitar Jones Offline
Kevin
And it's unsychronised, bonus!!
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: Guitar Jones] #1377027
02/02/13 02:41 AM
02/02/13 02:41 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Crashbox.... just like Liberty
Kevin
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: Twostick] #1377028
02/02/13 11:11 AM
02/02/13 11:11 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't dispute anyone's experiences. But how did anyone ever race Pro Stock in the 70s? Be it GM or Chrysler they were coupled to a 833 trans back in the day. Along with inferior clutch technology of that period it's amazing that Ronnie Sox ever finished a race.
Just asking, how did they do it?
Doug
Re: can a 833 23 splin hold up to over 800fpt & 900hp [Re: dvw] #1377029
02/02/13 11:12 AM
02/02/13 11:12 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Doug
I have have no doubt that those transmissions were coming out for refresh or being swapped after every event or even possibly every couple of races.
Page 3 of 3 1 2 3
