Car tires on a car trailer #1374039
01/21/13 11:36 PM
01/21/13 11:36 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
Can you use radial car tires for a car trailer hauling a 70 Challenger if the tires are rated at 1700lbs. each. Dual axles
Re: Car tires on a car trailer [Re: moparmikethree] #1374040
01/21/13 11:40 PM
01/21/13 11:40 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I would not do it but I have seen it on some trailers. There are tires specific for a trailer and some states will cite you if you do not have trailer specific tires on it.
Russ
Re: Car tires on a car trailer [Re: moparmikethree] #1374041
01/21/13 11:41 PM
01/21/13 11:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A lot of guys have run car tires on their trailers, but it's not a good idea, especially on a dual axle trailer IMO. A crappy little utility trailer with a 1000lb payload is one thing, but a real trailer really should have proper tires for safety sake. Trailer tires have thicker/stiffer sidewalls to withstand the torking and dragging that trailer tires see when you're taking a turn.
Re: Car tires on a car trailer [Re: DaytonaTurbo] #1374042
01/21/13 11:56 PM
01/21/13 11:56 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I agree with using trailer tires on a trailer. When I back my 28' fifth wheel camper into my driveway I watch the rim flex and the tire drag on the pavement. When I used a gooseneck equipment trailer with a skid steer on it the 10 ply radial tire wanted to roll off of the rim when I was backing it into the spot I park the camper. It bounced, jerked and made me nervous backing it into place.
Re: Car tires on a car trailer [Re: DaytonaTurbo] #1374043
01/21/13 11:59 PM
01/21/13 11:59 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You CAN run a P series tire on a car trailer according to NHSTA, but when doing so you MUST derate the tire by 10% of its max weight capacity.
An LT rated truck tire can be used at normal rating, just as an ST (trailer specific) tire can be.
Its very common to see many of the name brand trailer companies use the LT tires vs the ST tires. I would not recommend, nor use a P series tire on my own 5000# or larger GVW trailer.
This is not only for ease of replacement on the road, but also because many (if not most) of the ST rated tires are currently imported junk.
That said the trailer companies I have worked for have all used the BFG Commercial LT for tires in the 15 and 16 inch range, and then ST rated name brand tires for the 17.5 inch.
And when it comes to the 22.5 inch stuff, we let the customer decide what he wants to spend.
Also we recommend, and use Magnum balance beads in all sizes.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Car tires on a car trailer [Re: hp383] #1374044
01/22/13 12:15 AM
01/22/13 12:15 AM
North Texas
3
360cuda Offline
360cuda  Offline
North Texas
OK...I've owned a lot of trailers. You sound like you know what you are talking about. So at the risk of sounding ignorant, I need to ask; What is a Magnum balance bead?
Re: Car tires on a car trailer [Re: 360cuda] #1374045
01/22/13 12:19 AM
01/22/13 12:19 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Re: Car tires on a car trailer [Re: 360cuda] #1374046
01/22/13 12:22 AM
01/22/13 12:22 AM
Houston Texas
daredevil Offline
daredevil  Offline
Houston Texas
good info
pentastar power
Re: Car tires on a car trailer [Re: hp383] #1374047
01/22/13 12:30 AM
01/22/13 12:30 AM
North Texas
3
360cuda Offline
360cuda  Offline
North Texas
http://magnumbalance.com/
WOW. Good stuff. Very interesting web site. Thanks.
Re: Car tires on a car trailer [Re: moparmikethree] #1374048
01/22/13 05:16 AM
01/22/13 05:16 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Do it only if you like a little sway in the trailer
Dragging the on a twin axle will destroy them (sharp turns)& they will fail when you don't want them to
I would say that you would be setting yourself up for liability in an accident Some states have laws regarding the tires & brakes on trailers with more than 2 axles
Running a MH tire on a trailer down the interstate is illegal in most states due to the construction of the tire Besides a trailer radial by Carlisle will last quite a while & be safer
I ain't no saint I've ran car tires before but learned that trailer tires last longer & cost about the same
Re: Car tires on a car trailer [Re: BulletBob] #1374049
01/22/13 12:19 PM
01/22/13 12:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Personally I don't like car tires on ANY trailer.
Re: Car tires on a car trailer [Re: justinp61] #1374050
01/22/13 03:36 PM
01/22/13 03:36 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I like to get up to 90 mph sometimes, and I have yet to see a trailer tire hold up, so I'll keep using car tires, I run em till they are bald. Now my trailer is just a 16' two axle bumper type hitch.
Re: Car tires on a car trailer [Re: cageman] #1374051
01/22/13 04:55 PM
01/22/13 04:55 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Good-luck with that in Pennsylvania. We had several trailers break loose and kill a few people from careless people and improper hauling. Car trailers and landscaping trailers are being pulled over more often and inspected closely. Overweight trailers, un-inspected trailers, no brakes on trailers over 3000# pounds, safety chains not crossed properly, wrong tires, and lights are being targeted. And the fines add up real quick.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Car tires on a car trailer [Re: hp383] #1374052
01/22/13 05:51 PM
01/22/13 05:51 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Best post.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Car tires on a car trailer [Re: DPelletier] #1374053
01/22/13 10:00 PM
01/22/13 10:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Trailer specific tires have largely been junk for years now. All I run are non trailer tires on my stuff. But I did that long before the trailer tire production went overseas and to crap.
I have buddies that have had more trouble with newer trailer tires than I have had with used car tires.
Master, again and still
Re: Car tires on a car trailer [Re: DaveRS23] #1374054
01/22/13 10:22 PM
01/22/13 10:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: Car tires on a car trailer [Re: MoparforLife] #1374055
01/22/13 10:37 PM
01/22/13 10:37 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
From what I've seen, there are the $75.00 trailer specific tires and then there are the $125.00 ones....DON'T go with the cheap ones for obvious reasons!!
That being said...there has to be a fine line drawn as to whether one is running NEW P rated tires or using a set of WELL used ones.
At the MATS this year, I was astounded to see what some guys had on their trailers....especially when they had been towing at freeway speeds for days!! Blew my mind!!!
Some of these guys had $40000 cars on the trailers and s**t tires (bald) on the trailer.
I value my ride a little more than that...
Re: Car tires on a car trailer [Re: superwrench] #1374056
01/22/13 10:45 PM
01/22/13 10:45 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i use car tires, no problems yet
Re: Car tires on a car trailer [Re: d-150] #1374057
01/22/13 11:00 PM
01/22/13 11:00 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I used to run car tires on my open 16' trailer with no problems what so ever and they held up good. Now on my 20' enclosed I run the trailer tires as the extra weight I think would be too much for car tires
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Car tires on a car trailer [Re: G-Money1320] #1374058
01/23/13 01:06 AM
01/23/13 01:06 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The best tires that I've seen yet that lasted & carried the weight without swaying were the Hoosier tires that they use on asphalt tracks in the street stock division we used them on a 18' steel deck trailer & towed 80+ going to different tracks with a 3500# car on it. They can take the heat generated by the weight & speed
