Re: Car tires on a car trailer
[Re: DaytonaTurbo]
#1374043
01/21/13 11:59 PM
01/21/13 11:59 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
You CAN run a P series tire on a car trailer according to NHSTA, but when doing so you MUST derate the tire by 10% of its max weight capacity. An LT rated truck tire can be used at normal rating, just as an ST (trailer specific) tire can be. Its very common to see many of the name brand trailer companies use the LT tires vs the ST tires. I would not recommend, nor use a P series tire on my own 5000# or larger GVW trailer. This is not only for ease of replacement on the road, but also because many (if not most) of the ST rated tires are currently imported junk. That said the trailer companies I have worked for have all used the BFG Commercial LT for tires in the 15 and 16 inch range, and then ST rated name brand tires for the 17.5 inch. And when it comes to the 22.5 inch stuff, we let the customer decide what he wants to spend. Also we recommend, and use Magnum balance beads in all sizes.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: moparmikethree]
#1374048
01/22/13 05:16 AM
01/22/13 05:16 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
Can you use radial car tires for a car trailer hauling a 70 Challenger if the tires are rated at 1700lbs. each. Dual axles
Do it only if you like a little sway in the trailer Dragging the on a twin axle will destroy them (sharp turns)& they will fail when you don't want them to
I would say that you would be setting yourself up for liability in an accident Some states have laws regarding the tires & brakes on trailers with more than 2 axles Running a MH tire on a trailer down the interstate is illegal in most states due to the construction of the tire Besides a trailer radial by Carlisle will last quite a while & be safer
I ain't no saint I've ran car tires before but learned that trailer tires last longer & cost about the same
[Re: hp383]
#1374052
01/22/13 05:51 PM
01/22/13 05:51 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Best post.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1374053
01/22/13 10:00 PM
01/22/13 10:00 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Trailer specific tires have largely been junk for years now. All I run are non trailer tires on my stuff. But I did that long before the trailer tire production went overseas and to crap. I have buddies that have had more trouble with newer trailer tires than I have had with used car tires.
Master, again and still
[Re: DaveRS23]
#1374054
01/22/13 10:22 PM
01/22/13 10:22 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
[Re: MoparforLife]
#1374055
01/22/13 10:37 PM
01/22/13 10:37 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
From what I've seen, there are the $75.00 trailer specific tires and then there are the $125.00 ones....DON'T go with the cheap ones for obvious reasons!! That being said...there has to be a fine line drawn as to whether one is running NEW P rated tires or using a set of WELL used ones. At the MATS this year, I was astounded to see what some guys had on their trailers....especially when they had been towing at freeway speeds for days!! Blew my mind!!! Some of these guys had $40000 cars on the trailers and s**t tires (bald) on the trailer. I value my ride a little more than that...
