Lower control arm & drag link situation
#1372585
01/20/13 01:19 AM
01/20/13 01:19 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. I think I know the problem, but it isn't real clear. I'm putting the front suspension back together with new ball joints, bushings, tie-rods, etc... Now, all of a sudden, the drag link is rubbing against the oil pan ( obviously, it wasn't doing this before ). The same pitman and idler arm are back in the car, so the geometry should be the same. The drag link should be positioned in space with the drag link and idler arm. But, I may have the lower control arm one hex-side off on the torsion bar. I believe the lower control arm needs to swing up one more hex position. Maybe a fresh set of eyes will see something that's obvious for I'm getting tired at this hour.... And yes, I painted the lower control arms black... , next time I do the car, it'll get the "cosmoline" treatment....... Thanks in advance... Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Lower control arm & drag link situation
[Re: hemi68charger]
#1372587
01/20/13 01:24 AM
01/20/13 01:24 AM
RapidRobert
Do you still have the old tie rod end etc that were replaced so you can compare them?
[Re: RapidRobert]
#1372588
01/20/13 01:34 AM
01/20/13 01:34 AM
hemi68charger
Houston, Tx
Yeap and they look pretty close to each other. I know the space between the pan and the drag link are already close, but not rubbing-close....
[Re: hemi68charger]
#1372589
01/20/13 01:38 AM
01/20/13 01:38 AM
Posts: 4,872 connecticut
pnypwr
connecticut
the lca shouldnt have anything to do with pan to drag link clearance...is the drag link in backwards? im assuming you didnt change oil pans
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1372590
01/20/13 01:47 AM
01/20/13 01:47 AM
hemi68charger
Houston, Tx
That's what my understanding is, thanks for the reassurance. Now, I do believe the drag link is in properly, it's curved part is facing down and aft.... I can't image it is in backwards.. But, I will take it out and test fit it again....
[Re: pnypwr]
#1372591
01/20/13 01:53 AM
01/20/13 01:53 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Try turning the centerlink around.
But to clarify, you just did the suspension repair you listed above? No motor mount, trans mount, steering box, or anything else?
[Re: autoxcuda]
#1372592
01/20/13 02:12 AM
01/20/13 02:12 AM
hemi68charger
Houston, Tx
I pulled the steering box and had it serviced. It's the same box with the same output shaft and all. I once had a drag link in backwards, but could have sworn in was much more obvious at being backwards.....
[Re: hemi68charger]
#1372593
01/20/13 02:35 AM
01/20/13 02:35 AM
autoxcuda
So Cal
The steering box would have to have be tilted up somehow. Or the spline shaft moved up significantly (IIRC, not posible).
Could something be holding the steering box from being tightened/mated completely to the steering box pad on the K-member? Debris or something stuck in there?
Or the weld nuts in the K-member stripped badly. That does happen.
Check by trying to slip a feeler gauge or something thin between each 3 steering box bolts and K-member. Might be tough as hell to do though with the limite room in there.
On an aside: I've actually got a steering box not to mount properly before. I went overboard with the bracing when reinforcing a K-member. Fixed it by
[Re: autoxcuda]
#1372594
01/20/13 11:34 AM
01/20/13 11:34 AM
hemi68charger
Houston, Tx
The steering box is in fine. Anyone have a picture of the draglink installed with the motor in the car? I could have sworn the service manual illustrated the draglink's bend going aft, not forward...
[Re: hemi68charger]
#1372597
01/20/13 02:23 PM
01/20/13 02:23 PM
autoxcuda
So Cal
Could you just look at you Daytona for reference?
[Re: autoxcuda]
#1372598
01/20/13 03:19 PM
01/20/13 03:19 PM
hemi68charger
Houston, Tx
The Daytona's the issue. I can use the 500 for reference.. In all honesty, I think the oil pan that's on the motor is a C-body pan. The clearance was always close and the 500 is real close too. I know for a fact the 500 has a '69 New Yorker 440 in it ( pulled straight out of the New Yorker into the 500. ). I'm going to go get the 3-digit number off the bottom of the pan, maybe that will shine some light on the issue. If it is the wrong pan, time for me to get proper one....
[Re: hemi68charger]
#1372599
01/20/13 03:55 PM
01/20/13 03:55 PM
hemi68charger
Houston, Tx
I believe I have the culprit... I have a 187 pan on my Daytona, hence a 2.02" depth pan whereas the 402 I'm suppose to have is a 1.56" depth pan... I believe that's my culprit. I put everything back to what it was before. Apparently my tolerances were a lot closer than I remembered, didn't really pay no mind to it before since it worked. Maybe the draglink was backwards and cleared. Regardless, I'm going to put it the proper way. I'll remove the draglink, get a proper pan and put it all back together again. Thus, making the Daytona even "more correct"... The life these old cars go through. The previous owner apparently didn't have a 402 pan laying around when they built this 69 440 for the Daytona when they yanked the 426 Hemi that was in it when it came back from England...
[Re: hemi68charger]
#1372600
01/20/13 03:57 PM
01/20/13 03:57 PM
hemi68charger
Houston, Tx
the "187" stamping, verifying it is indeed a C-body pan... Now the quest to get a 402 pan... Maybe I have that ole' Hemi pan laying around I can use for barter....
Thanks Charlie, your link was the key to understanding.....
[Re: hemi68charger]
#1372601
01/20/13 05:14 PM
01/20/13 05:14 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
While the 402 is correct I'd use a Repo Hemi pan with the larger sump... Better yet Milodon makes a repo Hemi pan that when painted looks nearly correct but to nice as their stamping dies are better plus their welds are TIG instead of spot welds so the baffles are more secure...
MILODON 30761
[Re: 1_WILD_RT]
#1372602
01/21/13 12:26 AM
01/21/13 12:26 AM
hemi68charger
Houston, Tx
Well, guess what....... I have to start going up into my attic more to see my Mopar stash... Pull this down. I need a 402 oil and what I believe I found is a '70-'71 426 Hemi oil pan.... I'll see if I can trade it for 2 "402" pans....
