Lower control arm & drag link situation #1372585
01/20/13 01:19 AM
01/20/13 01:19 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
I think I know the problem, but it isn't real clear. I'm putting the front suspension back together with new ball joints, bushings, tie-rods, etc... Now, all of a sudden, the drag link is rubbing against the oil pan ( obviously, it wasn't doing this before ). The same pitman and idler arm are back in the car, so the geometry should be the same. The drag link should be positioned in space with the drag link and idler arm. But, I may have the lower control arm one hex-side off on the torsion bar. I believe the lower control arm needs to swing up one more hex position. Maybe a fresh set of eyes will see something that's obvious for I'm getting tired at this hour....
And yes, I painted the lower control arms black... , next time I do the car, it'll get the "cosmoline" treatment.......
Thanks in advance...
Troy
Troy
Houston Mopar Connection Club
Re: Lower control arm situation [Re: hemi68charger] #1372586
01/20/13 01:20 AM
01/20/13 01:20 AM
Houston, Tx
Houston, Tx
Lower Control arm area..
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372587
01/20/13 01:24 AM
01/20/13 01:24 AM
Do you still have the old tie rod end etc that were replaced so you can compare them?
Re: Lower control arm & drag link situation [Re: RapidRobert] #1372588
01/20/13 01:34 AM
01/20/13 01:34 AM
Houston, Tx
Houston, Tx
Yeap and they look pretty close to each other. I know the space between the pan and the drag link are already close, but not rubbing-close....
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372589
01/20/13 01:38 AM
01/20/13 01:38 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
the lca shouldnt have anything to do with pan to drag link clearance...is the drag link in backwards? im assuming you didnt change oil pans
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Lower control arm & drag link situation [Re: pnypwr] #1372590
01/20/13 01:47 AM
01/20/13 01:47 AM
Houston, Tx
Houston, Tx
That's what my understanding is, thanks for the reassurance. Now, I do believe the drag link is in properly, it's curved part is facing down and aft.... I can't image it is in backwards.. But, I will take it out and test fit it again....
Troy
Re: Lower control arm & drag link situation [Re: pnypwr] #1372591
01/20/13 01:53 AM
01/20/13 01:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Try turning the centerlink around.
But to clarify, you just did the suspension repair you listed above? No motor mount, trans mount, steering box, or anything else?
Re: Lower control arm & drag link situation [Re: autoxcuda] #1372592
01/20/13 02:12 AM
01/20/13 02:12 AM
Houston, Tx
Houston, Tx
I pulled the steering box and had it serviced. It's the same box with the same output shaft and all. I once had a drag link in backwards, but could have sworn in was much more obvious at being backwards.....
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372593
01/20/13 02:35 AM
01/20/13 02:35 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The steering box would have to have be tilted up somehow. Or the spline shaft moved up significantly (IIRC, not posible).
Could something be holding the steering box from being tightened/mated completely to the steering box pad on the K-member? Debris or something stuck in there?
Or the weld nuts in the K-member stripped badly. That does happen.
Check by trying to slip a feeler gauge or something thin between each 3 steering box bolts and K-member. Might be tough as hell to do though with the limite room in there.
On an aside: I've actually got a steering box not to mount properly before. I went overboard with the bracing when reinforcing a K-member. Fixed it by
Re: Lower control arm & drag link situation [Re: autoxcuda] #1372594
01/20/13 11:34 AM
01/20/13 11:34 AM
Houston, Tx
Houston, Tx
The steering box is in fine. Anyone have a picture of the draglink installed with the motor in the car? I could have sworn the service manual illustrated the draglink's bend going aft, not forward...
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372595
01/20/13 11:59 AM
01/20/13 11:59 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Was there any shims on the steering box that didn't get put back on? Does the idler arm bolt hole have some slop, try loosening the bolt and pull down on the idler.
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372596
01/20/13 02:08 PM
01/20/13 02:08 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
My money's on the drag link being in backwards.
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372597
01/20/13 02:23 PM
01/20/13 02:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Could you just look at you Daytona for reference?
Re: Lower control arm & drag link situation [Re: autoxcuda] #1372598
01/20/13 03:19 PM
01/20/13 03:19 PM
Houston, Tx
Houston, Tx
The Daytona's the issue. I can use the 500 for reference.. In all honesty, I think the oil pan that's on the motor is a C-body pan. The clearance was always close and the 500 is real close too. I know for a fact the 500 has a '69 New Yorker 440 in it ( pulled straight out of the New Yorker into the 500. ). I'm going to go get the 3-digit number off the bottom of the pan, maybe that will shine some light on the issue. If it is the wrong pan, time for me to get proper one....
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372599
01/20/13 03:55 PM
01/20/13 03:55 PM
Houston, Tx
Houston, Tx
I believe I have the culprit... I have a 187 pan on my Daytona, hence a 2.02" depth pan whereas the 402 I'm suppose to have is a 1.56" depth pan... I believe that's my culprit. I put everything back to what it was before. Apparently my tolerances were a lot closer than I remembered, didn't really pay no mind to it before since it worked. Maybe the draglink was backwards and cleared. Regardless, I'm going to put it the proper way. I'll remove the draglink, get a proper pan and put it all back together again. Thus, making the Daytona even "more correct"... The life these old cars go through. The previous owner apparently didn't have a 402 pan laying around when they built this 69 440 for the Daytona when they yanked the 426 Hemi that was in it when it came back from England...
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372600
01/20/13 03:57 PM
01/20/13 03:57 PM
Houston, Tx
Houston, Tx
the "187" stamping, verifying it is indeed a C-body pan... Now the quest to get a 402 pan... Maybe I have that ole' Hemi pan laying around I can use for barter....
Thanks Charlie, your link was the key to understanding.....
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372601
01/20/13 05:14 PM
01/20/13 05:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
While the 402 is correct I'd use a Repo Hemi pan with the larger sump... Better yet Milodon makes a repo Hemi pan that when painted looks nearly correct but to nice as their stamping dies are better plus their welds are TIG instead of spot welds so the baffles are more secure...
MILODON 30761
Re: Lower control arm & drag link situation [Re: 1_WILD_RT] #1372602
01/21/13 12:26 AM
01/21/13 12:26 AM
Houston, Tx
Houston, Tx
Well, guess what....... I have to start going up into my attic more to see my Mopar stash... Pull this down. I need a 402 oil and what I believe I found is a '70-'71 426 Hemi oil pan.... I'll see if I can trade it for 2 "402" pans....
Troy
Re: Lower control arm & drag link situation [Re: hemi68charger] #1372603
01/21/13 04:50 AM
01/21/13 04:50 AM
I would put that later street Hemi/440 6 pak oil pan on the car with the proper 440 6 pak 3/8 pickup If you really want a original 402 oil pan and NOS Mopar pickup I have a 402 pan that needs a little work on one corner that I would trade with you on on that later oil pan, I like the later ones a lot
