Dowel pins location #1368404
01/12/13 12:29 PM
01/12/13 12:29 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Can somebody show to me where the dowel pins go installed on a 440 block surface?
There are several holes where they fit,but i don,t know if any of them will be ok or if they need to go on a particular hole.
Thanks a lot for any input.
Re: Dowel pins location [Re: Coke] #1368405
01/12/13 12:59 PM
01/12/13 12:59 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't have a picture but they go on the ends. if you draw a line from front to back, across the cylinder holes, the dowel pins would be in that line. look for one hole on each end that is "shallow" and has a bottom. there's oil holes and water holes and bolt holes, you don't want any of them.
**Photobucket sucks**
Re: Dowel pins location [Re: 70Cuda383] #1368406
01/12/13 01:00 PM
01/12/13 01:00 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
use your heads to help locate the holes.
Re: Dowel pins location [Re: Coke] #1368407
01/12/13 02:32 PM
01/12/13 02:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Here is a big warning ... they are NOT .250 holes , I can't convert that to metric , sorry , the dowels I want to say are .246ish
Re: Dowel pins location [Re: JohnRR] #1368408
01/12/13 03:07 PM
01/12/13 03:07 PM
AndyF Offline
AndyF  Offline
They aren't standard .250 dowel nor are they metric. Chrysler engineers used a custom dowel pin for some unknown reason.
I think they are 0.2465 which would be a slight press fit into a letter D drill hole.
Re: Dowel pins location [Re: Coke] #1368409
01/12/13 07:46 PM
01/12/13 07:46 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
My question sounds stupid after being messing around for a while...
They are blind holes so there is not doubt.This year i promise to check the things before posting
About the sizes,i haven,t meassured them but i had to tape them a little in the left side and glue them in the right .
The heads seated ok anyway.
