Re: Dowel pins location
[Re: Coke]
#1368405
01/12/13 12:59 PM
01/12/13 12:59 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't have a picture but they go on the ends. if you draw a line from front to back, across the cylinder holes, the dowel pins would be in that line. look for one hole on each end that is "shallow" and has a bottom. there's oil holes and water holes and bolt holes, you don't want any of them.
**Photobucket sucks**
[Re: Coke]
#1368407
01/12/13 02:32 PM
01/12/13 02:32 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Can somebody show to me where the dowel pins go installed on a 440 block surface? There are several holes where they fit,but i don,t know if any of them will be ok or if they need to go on a particular hole.
Thanks a lot for any input.
Here is a big warning ... they are NOT .250 holes , I can't convert that to metric , sorry , the dowels I want to say are .246ish
[Re: Coke]
#1368409
01/12/13 07:46 PM
01/12/13 07:46 PM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
My question sounds stupid after being messing around for a while... They are blind holes so there is not doubt.This year i promise to check the things before posting About the sizes,i haven,t meassured them but i had to tape them a little in the left side and glue them in the right . The heads seated ok anyway.
