C body ball joints HELP!!!!!!!!!! #1368352
01/12/13 02:37 AM
01/12/13 02:37 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
ive been digging all day online for lower ball joints for my 68 chrysler newport it has the disk breaks frount with the one year only kelsey hayes 4 piston calipers i found some sites that have them but not for he kelsey hayes breaks they have 4 holes insted of two and i just cant find them can any body help me!!! my car has been torn down for two weeks because i cant find the ball joints
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: C body ball joints HELP!!!!!!!!!! [Re: gogo318] #1368353
01/12/13 02:40 AM
01/12/13 02:40 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: C body ball joints HELP!!!!!!!!!! [Re: 340SHORTY] #1368354
01/12/13 04:42 PM
01/12/13 04:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
www.rareparts.com
I bought an idler arm from Rare Parts for my 72 Imperial. It's a reman but a real nice part.
- Stu Harmon
Re: C body ball joints HELP!!!!!!!!!! [Re: feets] #1368355
01/12/13 06:16 PM
01/12/13 06:16 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Rare item- try Kanter also.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: C body ball joints HELP!!!!!!!!!! [Re: EWJ] #1368356
01/12/13 07:27 PM
01/12/13 07:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
open wallet wide
Re: C body ball joints HELP!!!!!!!!!! [Re: 05dakota] #1368357
01/12/13 07:42 PM
01/12/13 07:42 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
FYI
Your Chrysler has BUDD disc brakes on it, not Kelsey Hayes.
And the big Chrysler's used them from 1966 to 68, and the Imperials used them until 1969.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: C body ball joints HELP!!!!!!!!!! [Re: EWJ] #1368358
01/12/13 07:59 PM
01/12/13 07:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Not sure if you are an original parts only guy but those Budd brakes are a money pit.
The simple solution is to get a set of 69-72 or 73 C-body spindles and lower balljoints. Balljoint is the same from 65-73. 73 is the preferable spindle because the 73 rotor is 1/3 the price of the 69-72 rotor but is getting hard to find because it's 1 year only. The rest of the parts like balljoints, pads and calipers are the same and readily available.
Kevin
Re: C body ball joints HELP!!!!!!!!!! [Re: Twostick] #1368359
01/12/13 10:03 PM
01/12/13 10:03 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
I've got a pair of used one's off my 68 Sport Fury that I replaced the brake's with the 73 era one's because I could'nt find new/re-man calipers. Muskegon brake said they could sleeve them but it was SUPER expensive and the car's not a rare numbers matching car so I swapped everything over.
I saved all my old parts and have the lower's if you need them. Just let me know.
Re: C body ball joints HELP!!!!!!!!!! [Re: Twostick] #1368360
01/13/13 10:09 AM
01/13/13 10:09 AM
dart1962_440 Offline
Kevin
I believe 73 rotors were also used on trucks & vans until around 1980 so there should be more available than earlier styles.
Re: C body ball joints HELP!!!!!!!!!! [Re: dart1962_440] #1368361
01/13/13 05:36 PM
01/13/13 05:36 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
That's why they are cheaper. They used the same rotor on c's, vans and d100's from 73 until the trucks went to 5x5.5 bolt circle in the early 80's. I'm assuming the B series van switched bolt circles at the same time the trucks did.
I've heard a rumor that they are machining the unicast rotor for the 72 and earlier spindle size but the price is still 3x's the 73 style.
Still WAY cheaper than lower balljoints, rotors and calipers for a Budd system.
Kevin
Re: C body ball joints HELP!!!!!!!!!! [Re: gogo318] #1368362
01/17/13 06:38 PM
01/17/13 06:38 PM
OHIO
BUBBAZ572 Offline
MR. CAPS LOCK
BUBBAZ572  Offline
MR. CAPS LOCK
OHIO
TRY ALLREGGTA BRAKES AND CHASSIS
1-888-257-3882
Re: C body ball joints HELP!!!!!!!!!! [Re: BUBBAZ572] #1368363
01/19/13 01:40 AM
01/19/13 01:40 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Mid-Canada Suspension specializes in obsolete stuff. One man show apparently.
http://www.members.shaw.ca/midcansusp/index.htm
Kevin
Re: C body ball joints HELP!!!!!!!!!! [Re: Twostick] #1368364
01/25/13 09:31 PM
01/25/13 09:31 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
ok so my ball joints seem to be serviceable for a lil while longer but i will need to do something about them eventually i have access to a all drums 68 newport should i just convert it to that? my rotors are great and i just bought new calipers (300 bucks worth) i can get my pads relined for 14 bucks local cause they cant be found replacement my car isnt # matching (hell its got a 318/904 from an 85 truck) i just want it to last i want it to be a daily driver
Re: C body ball joints HELP!!!!!!!!!! [Re: gogo318] #1368365
01/26/13 01:29 AM
01/26/13 01:29 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you are going to convert it to anything, go find a 73 C-body and get the spindles off it. 69-73 disc brake spindles use the same lower ball joint as the drum brake cars back to 65. If the ball joints on the 68 drum car are serviceable, use them. everything else you can buy at your favorite parts store including the lower joints if you need them.
It sounds like you can still drive the car as is so I would start shopping for for a 73 donor car. 69-72 will work also and are more plentiful but the rotors are more expensive. Other than that, they are the same as the 73. Same rotor size, same calipers, pads, etc.
Kevin
Re: C body ball joints HELP!!!!!!!!!! [Re: Twostick] #1368366
01/26/13 02:45 AM
01/26/13 02:45 AM
Southern CA
Colin Frolick Offline
Southern CA
http://ubmachine.com/balljointsleeves.html
cut up your lower arm and weld in a ring to use the common mopar k727 lower ball joint... or whatever common ball joint will fit your spindle's taper. you could even ream the spindle to make a better ball joint fit.
we did something like this to my buddy's '64 fairlane because the lower ball joints for it are stupid expensive.
Re: C body ball joints HELP!!!!!!!!!! [Re: Colin Frolick] #1368367
01/27/13 04:19 PM
01/27/13 04:19 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm not sure how you would make that work with this.
Kevin
Re: C body ball joints HELP!!!!!!!!!! [Re: Twostick] #1368368
01/28/13 02:09 AM
01/28/13 02:09 AM
Southern CA
Southern CA
Kevin
ick. well then i got nothing
Re: C body ball joints HELP!!!!!!!!!! [Re: Colin Frolick] #1368369
01/28/13 01:43 PM
01/28/13 01:43 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think those sleeves are more for repairing control arms that have screw in joints.
His practical solution is to get the disc brake spindles and ball joints from a 69-73 preferably 73 C-body and call it a day.
Kevin
Re: C body ball joints HELP!!!!!!!!!! [Re: Twostick] #1368370
01/28/13 04:10 PM
01/28/13 04:10 PM
Southern CA
Southern CA
so here is the difference in a c-body vs. imperial front suspension. i didn't know they were that different.
Re: C body ball joints HELP!!!!!!!!!! [Re: Colin Frolick] #1368371
01/30/13 06:39 PM
01/30/13 06:39 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Yeah, practically nothing interchanges between the 67-73 unibody Imperials and C bodies suspension-wise other than maybe the shocks. The 69-73 cars look similar, but from the firewall forward they were still their own car.
