Re: C body ball joints HELP!!!!!!!!!!
[Re: feets]
#1368355
01/12/13 06:16 PM
01/12/13 06:16 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Rare item- try Kanter also.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: EWJ]
#1368356
01/12/13 07:27 PM
01/12/13 07:27 PM
Posts: 17,861 albany ny
05dakota
albany ny
[Re: Twostick]
#1368360
01/13/13 10:09 AM
01/13/13 10:09 AM
Posts: 629 Michigan
dart1962_440
Not sure if you are an original parts only guy but those Budd brakes are a money pit.
The simple solution is to get a set of 69-72 or 73 C-body spindles and lower balljoints. Balljoint is the same from 65-73. 73 is the preferable spindle because the 73 rotor is 1/3 the price of the 69-72 rotor but is getting hard to find because it's 1 year only. The rest of the parts like balljoints, pads and calipers are the same and readily available.
Kevin
I believe 73 rotors were also used on trucks & vans until around 1980 so there should be more available than earlier styles.
[Re: dart1962_440]
#1368361
01/13/13 05:36 PM
01/13/13 05:36 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin
That's why they are cheaper. They used the same rotor on c's, vans and d100's from 73 until the trucks went to 5x5.5 bolt circle in the early 80's. I'm assuming the B series van switched bolt circles at the same time the trucks did.
I've heard a rumor that they are machining the unicast rotor for the 72 and earlier spindle size but the price is still 3x's the 73 style.
Still WAY cheaper than lower balljoints, rotors and calipers for a Budd system.
Kevin
[Re: Twostick]
#1368366
01/26/13 02:45 AM
01/26/13 02:45 AM
Posts: 236 Southern CA
Colin Frolick
Southern CA
http://ubmachine.com/balljointsleeves.htmlcut up your lower arm and weld in a ring to use the common mopar k727 lower ball joint... or whatever common ball joint will fit your spindle's taper. you could even ream the spindle to make a better ball joint fit. we did something like this to my buddy's '64 fairlane because the lower ball joints for it are stupid expensive.
[Re: Twostick]
#1368368
01/28/13 02:09 AM
01/28/13 02:09 AM
Colin Frolick
Southern CA
I'm not sure how you would make that work with this.
Kevin
ick. well then i got nothing
[Re: Colin Frolick]
#1368371
01/30/13 06:39 PM
01/30/13 06:39 PM
Posts: 4,588 St. John's Newfoundland
440newport
so here is the difference in a c-body vs. imperial front suspension. i didn't know they were that different.
Yeah, practically nothing interchanges between the 67-73 unibody Imperials and C bodies suspension-wise other than maybe the shocks. The 69-73 cars look similar, but from the firewall forward they were still their own car.
