Disc brakes. Pin or slider???? #1366307
01/08/13 11:49 AM
01/08/13 11:49 AM
Western Colorado High Desert
moparmarks Offline OP
On the 70's factory disc which do you prefer, pin or slider calipers?
pin or slider
single choice
pin
57%, 17 Votes
slider
43%, 13 Votes
Total Votes: 30
Voting on this poll ends: 01/13/13 10:48 AM
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Disc brakes. Pin or slider???? [Re: moparmarks] #1366308
01/08/13 12:56 PM
01/08/13 12:56 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Pins are probably a better design, however the sliders are more prolific out there . . . used sliders on my 70 Sport Satellite . . .
Just depends on parts you find/use . . .
Cheers
Mark
Re: Disc brakes. Pin or slider???? [Re: a12rag] #1366309
01/08/13 03:52 PM
01/08/13 03:52 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I've had both. If you properly maintain them there is no difference. I think one of them has better pad selection but I forget which one that is.
Re: Disc brakes. Pin or slider???? [Re: bordin34] #1366310
01/09/13 07:29 AM
01/09/13 07:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pin type has better brake slection.I run ceramics on the 65.Rocky
Chrysler Firepower
Re: Disc brakes. Pin or slider???? [Re: moparmarks] #1366311
01/09/13 01:34 PM
01/09/13 01:34 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Pins have a bit less residual friction and require less maintenance to remain that way. Pins also have longer max. piston stroke, allowing more horrors before losing the fluid (not that any of us would ever allow that).
Still, 6 of one, 1/2-dozen of the other...and sliders are much more available.
Rick
Re: Disc brakes. Pin or slider???? [Re: moparmarks] #1366312
01/09/13 08:43 PM
01/09/13 08:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I like the pin type because I got them for free
Gus
64 Plymouth Savoy
Dana 60
Re: Disc brakes. Pin or slider???? [Re: fourgearsavoy] #1366313
01/09/13 11:42 PM
01/09/13 11:42 PM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
MOST VENDERS HAVE DONE/ MADE BOTH..MOST NEW STUFF LEANS BACK TOWARD PIN TYPES
FIXED ARE BEST
Re: Disc brakes. Pin or slider???? [Re: Rick_Ehrenberg] #1366314
01/10/13 12:56 AM
01/10/13 12:56 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I get confused( the old thing) Which one is pin and which one is slider.
Re: Disc brakes. Pin or slider???? [Re: 71birdJ68] #1366315
01/10/13 10:30 AM
01/10/13 10:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pin thype has 2 pins that hold the pad and calipar in place and go thru the pad.Slider type just slides in and has the 2 5/16s shrt bolts that go into the bracket from the top.They have the small pieces that go under the bolt that keeps them from lifting.Rocky
Chrysler Firepower
