Page 1 of 3 1 2 3
Third rear seal leaking - very frustrated!!! #1366147
01/08/13 12:10 AM
01/08/13 12:10 AM
GTX Mike Offline OP
GTX Mike  Offline OP
440 Source crank (not knurled) with a 440 Source billet retainer. When I first put the motor together, i used a Viton seal from 440 Source and the orange silicone side seals. It leaked. The leak was definitely from the seal, not the side seals. So I decided to try a rope seal instead. That leaked too. So I decided that maybe the problem was from the back of the engine or I just didn't do a good enough job with the rope seal. I re-did the rope seal (Victor Reinz JV551}, removed the trans. and checked the back of the engine, which was dry. I grooved the retainer to make sure oil could easily flow down from the rear main cap. Today I ran it for about 40 minutes. For the first 20 minutes, it was dry. But right when I was starting to feel good, it started leaking pretty heavily - like about 2 to 3 ounces in the next 20 minutes. Again, I'm sure it's leaking from the crank and not the side seals (I can see a drop on the crank}.
I've rebuilt probably 20 engines in the past, but the only two I've ever had rear seal trouble with are this one and my last big block (another 440 Source crank). On my last 440 Source crank, I had a knurled crank. I put a rubber seal on it, and it leaked, but I then installed a rope seal (with an Indy retainer) and it was fine.
The one constant here is the rear seal retainer. I almost replaced it this last time just to be cautious. 440 Source recommends shaving 0.010 off their retainer. I didn't do this, since I'm using a rope seal, and I figured it would make no difference.
Re: Third rear seal leaking - very frustrated!!! [Re: GTX Mike] #1366148
01/08/13 12:31 AM
01/08/13 12:31 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I'm using a stock steel crank and a 440 Source retainer with the rubber seal and pipe cleaner/silicone side seals that comes in the FelPro engine kit. It's sealing fine after 2000 miles. With their retainer, they recommend you silicone every sealing surface on and around the retainer except for where the seal actually contacts the crank. Also in the groove in the retainer around the outside of the seal. Everywhere.
Re: Third rear seal leaking - very frustrated!!! [Re: bobs66440] #1366149
01/08/13 12:39 AM
01/08/13 12:39 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Read this and see if anything there can help:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Third rear seal leaking - very frustrated!!! [Re: autoxcuda] #1366150
01/08/13 05:03 AM
01/08/13 05:03 AM
GTX Mike Offline OP
GTX Mike  Offline OP
That was actually one of my primary references when I did the seal this last time. I found it interesting that some of the billet seal retainers have problems. I think I will either use another Indy retainer this time or go with a stock style.
Re: Third rear seal leaking - very frustrated!!! [Re: GTX Mike] #1366151
01/08/13 10:42 AM
01/08/13 10:42 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Doesn't the rope seal need to be used with a knurled crank ?
Re: Third rear seal leaking - very frustrated!!! [Re: JohnRR] #1366152
01/08/13 12:36 PM
01/08/13 12:36 PM
Dulles, VA
P
phathemi Offline
phathemi  Offline
P
Dulles, VA
I'm interested in following this thread, had my engine (440/stock crank, vyton seal, billet 440 cap), out three times for this too. I can't confirm the source of my leak. I've got a manual trans and I'm wondering how much crank bell housing run out can impact and make this leak. I'm just within mopar spec, barely, and makes me wonder if it's enough movement to cause this. I've also gone back to stock oil pressure sending unit and removed my mechanical just in case the oil was faking me out by running down the back and appearing to be a crank seal leak. frustrated is an understatement!
Re: Third rear seal leaking - very frustrated!!! [Re: phathemi] #1366153
01/08/13 12:45 PM
01/08/13 12:45 PM
bobs66440 Offline
bobs66440  Offline
Did you silicone seal all the mating surfaces?
Re: Third rear seal leaking - very frustrated!!! [Re: phathemi] #1366154
01/08/13 01:10 PM
01/08/13 01:10 PM
If there was enough pressure from an out of spec bellhousing to cause the crank to move I think you be eating input bearings on the trans and/or the pilot bushing, make sure the trans is not leaking , bearing retainer seal and gasket and especially around the cluster gear pin ...
Re: Third rear seal leaking - very frustrated!!! [Re: bobs66440] #1366155
01/08/13 01:15 PM
01/08/13 01:15 PM
GTX Mike Offline OP
GTX Mike  Offline OP
Absolutely. I'm always very generous with my RTV! Mating surfaces, back side of each seal, rear of seal retainer at mating surfaces (just in case the side seals leak).
Re: Third rear seal leaking - very frustrated!!! [Re: GTX Mike] #1366156
01/08/13 01:22 PM
01/08/13 01:22 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
You need to be careful that as everything is tightened down the silicone does not get on unintended surfaces. This happened to me after putting just enough silicon the second time there have been no issues.
What was I thinking....
Re: Third rear seal leaking - very frustrated!!! [Re: GTX Mike] #1366157
01/08/13 02:03 PM
01/08/13 02:03 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'd venture to say that's about 90% of leakage problems
Many are so damn afraid of a leak they think the "sillycone" is going to help them when in fact it causes more problems than it will cure. Especially on a rear main seal.
I can't believe people do this thinking it will "help" seal things up. I'll also take a wild azz guess that most people think about the rear seal just before they drop the crank in without any pre planning or fit up.
JohnRR
A rope seal on a smooth crank surface = potential leak.
Knocking .010" off a retainer? For what? I assume most that do this don't even consider mocking the seal up first. And BTW how is it suggested to take the .010" off, belt sander?
Who here Loctite's their bearings in place just to make sure they won't spin one?
When installing a rear seal, leave the sillycone in the tool box
Re: Third rear seal leaking - very frustrated!!! [Re: roadhazard] #1366158
01/08/13 02:40 PM
01/08/13 02:40 PM
Re: Third rear seal leaking - very frustrated!!! [Re: JohnRR] #1366159
01/08/13 03:13 PM
01/08/13 03:13 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I'd cut 5/10 thou off the retainer with a cap grinder - NOT a belt sander
It is possible the crank is under spec
FWIW - I always use a shaved Original Mopar retainer - with a rope seal - light silicone on sealing surfaces and fill in the sides - no issues
Since you have a smooth seal surface - shave the cap and get a good viton seal - lube the seal heavily for startup.
Re: Third rear seal leaking - very frustrated!!! [Re: JohnRR] #1366160
01/08/13 03:24 PM
01/08/13 03:24 PM
Dulles, VA
P
phathemi Offline
phathemi  Offline
P
Dulles, VA
Thanks JohnRR, my bell housing bore measures 8-9 1000th total out, just on the cusp of needing dowels. I also DID have an input shaft leak which I just had repaired after a glazed clutch, I'm fascinated that you thought of that. My input shaft was pitted at the seal which is what we are attributing failure to, not out of round....or could it be? regardless, it's engine oil dripping off the dust collector, not tranny fluid.
Re: Third rear seal leaking - very frustrated!!! [Re: SSAAHemiFan] #1366161
01/08/13 04:01 PM
01/08/13 04:01 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Did you measure and inspect his block to advise removing material from the seal retainer?
Removing .005" - .010" from the seal retainer has virtually NO effect when using a rope seal.
Removing the same amount for using a rubber seal can very well have a negative effect.
Does one make their housing bores on the rods or mains smaller to decrease bearing clearance?
Find the root cause of the problem, smooth shaft and rope seal, sillycone band-aid, retainer fitment and concentricity with the block and crank bores and parting surface alignment with a rubber seal for starters.
BTW a rod cap grinder is the proper method for removing material from the seal retainer
Re: Third rear seal leaking - very frustrated!!! [Re: roadhazard] #1366162
01/08/13 04:51 PM
01/08/13 04:51 PM
bobs66440 Offline
bobs66440  Offline
Bottom line: If I can invent a foolproof way of sealing big block Mopar rear main seals for everyone, I stand to win some kind of prize for the betterment of humanity or something, right?
Re: Third rear seal leaking - very frustrated!!! [Re: bobs66440] #1366163
01/08/13 07:22 PM
01/08/13 07:22 PM
dogdays Offline
dogdays  Offline
And become a billionaire!
R.
Re: Third rear seal leaking - very frustrated!!! [Re: dogdays] #1366164
01/08/13 08:22 PM
01/08/13 08:22 PM
GTX Mike Offline OP
GTX Mike  Offline OP
OK. Original poster here. I went home during lunch to scratch my head a little more to figure this out. I thought about crankcase ventilation, as I wasnt' planning to run PCV, since it's mainly a race car. I figured I was OK, since I have a filtered breather plugged into the valve cover. I took out the breather and blew through it. I was surprised to find strong resistance to my blowing, kind of like trying to blow up a balloon. I'm betting this is at least part of the problem (pressurized crankcase), and it would explain why the leak is somewhat intermittent (I ran the car for 20 minutes with no leak, then it started leaking heavily).
I'll post back when I find out.
Re: Third rear seal leaking - very frustrated!!! [Re: GTX Mike] #1366165
01/08/13 10:19 PM
01/08/13 10:19 PM
USA
Hooligan Offline
Hooligan  Offline
USA
I have a 440 source crank, their billet seal retainer, and their orange viton seal kit but I have yet to use them. If my aging memory serves me right...I think that Hughes Racing Engines now sells a nifty one-piece rubber rear main seal. It has a slit in it so you can slip it over the crank. If I am mistaken, then I will start taking my meds again!
Re: Third rear seal leaking - very frustrated!!! [Re: Hooligan] #1366166
01/08/13 11:07 PM
01/08/13 11:07 PM
GTX Mike Offline OP
GTX Mike  Offline OP
I hooked up a PCV system and, well, no change! The PCV system was working fine - the suction held a sheet of paper in place on the opposite valve cover. It doesn't seem to make any difference whether the crankcase is pressurized or under vacuum. At idle, it hardly leaks (maybe a drop every minute or so), but at rpm, it's more like a drop every 10 seconds.
That Hughes one-piece seal sounds cool. I'll have to look that up.
Page 1 of 3 1 2 3
