70 Dart TTI header install problems #136541
10/14/08 09:30 PM
10/14/08 09:30 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
Over the weekend I installed a new set of TTI headers on my 70 340 Dart. I had to have a spacer plate made for the driver side motor mount to lift up the motor a bit as the third header tube back was resting on the power steering box. Today I discovered that the steering center link rubs on one of the driver side header tubes when the wheel is turned to the left. I thought TTI headers were supposed to fit like a glove but not on my car they don't. Anyway, does anyone have a suggestion on how to get more clearance on the center link to avoid having the rubbing issue? The only thing I have changed is the car had manual steering and I installed power steering. The power steering box and pump were from a 70 318 Dart.
Re: 70 Dart TTI header install problems [Re: 6PAX] #136542
10/14/08 10:03 PM
10/14/08 10:03 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
I had many issues installing in a 68 340 barracuda.But I could see that it had been in an accident sometime in life.I shimmed the driver mount like you did,But I aslo slotted the frame and moved the engine back a little bit 1/4 inch maybe.been ok.loosen the trans mount bolt also,slide back.I also installed the shumacker engine bracket for extra caution.
Make sure the mounts are on the correct side of the block,also the drag link isn't flipped around.
Re: 70 Dart TTI header install problems [Re: 6PAX] #136543
10/15/08 05:19 AM
10/15/08 05:19 AM
Locomotion Offline
Locomotion  Offline
How old are the motor mounts? Over time, the rubber will settle/compress/wear out. Same thing for the trans mount, which will tilt the engine/trans assembly down.
Polyurethane mounts are durable, long lasting replacements.
Re: 70 Dart TTI header install problems [Re: Locomotion] #136544
10/15/08 12:33 PM
10/15/08 12:33 PM
Detroit area
Detroit area
I'm pretty sure the motor mount brackets are on the correct side of the mounts on the block. Should the brackets attach in front of or behind the mounts coming off of the block? Also, I had been wondering if it was possible that the drag link is reversed but I wasn't sure if it would bolt up if it was. Will it fit properly if it is reversed?
The motor mounts are fairly new as is the trans. mount.
Re: 70 Dart TTI header install problems [Re: 6PAX] #136545
10/18/08 03:27 PM
10/18/08 03:27 PM
Detroit area
Detroit area
Well, I've spent all day again today trying to solve the problem with my headers hitting the power steering box and still have no answer. Even after adding a 3/16" shim on the driver side the header tube still makes contact with the steering box. The only things I can think of to solve this is to either shim some more but I don't know how much I can shim without creating other problems, dent the header tube which I would rather not do or grind off the edge of the steering box to make clearance which would be a lot of work. I was also thinking of possibly using different motor mounts. The ones one the car are fairly new but only measure 7/8" thick with the motor sitting on them. My friend has Schumacher mounts on his car that are a little over an inch thick under load. According to Mancini's the correct thickness is 7/8" but maybe a thicker mount will solve the problem? Your thoughts please.
Re: 70 Dart TTI header install problems [Re: 6PAX] #136546
10/18/08 05:33 PM
10/18/08 05:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I remember reading something on the TTI website about trying to establish a specific measurement from the center of the balancer to the k-frame in order for the headers to fit properly??? Have you ran across anything in the instructions along those lines?
I have a set of TTI's, but have not put the car back together yet (paint job) to know all the details.
Re: 70 Dart TTI header install problems [Re: Neil] #136547
10/18/08 07:18 PM
10/18/08 07:18 PM
Tampa Florida
MoparTod Offline
MoparTod  Offline
Tampa Florida
I would call TTI directly. Although they do have some generic instructions on line you can print.
Re: 70 Dart TTI header install problems [Re: 6PAX] #136548
10/18/08 07:44 PM
10/18/08 07:44 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
I used Schumacher headers and mounts on my 440 Swinger with PS and was determined not to ding the headers. It was a real pain but I ground off part of the steering box to gain about 1/16 clearance. The headers have no dings anywhere. I also used the Schumacher torque strap to keep movement to a minimum.
Take your time and do your clearancing now not later. It will work just fine with a little effort.
Russ:)
BigBlock 74 Swinger
Re: 70 Dart TTI header install problems [Re: bb74swngr] #136549
10/18/08 08:28 PM
10/18/08 08:28 PM
West Central Indiana
Mr.Runum Offline
Mr.Runum  Offline
I agree DO NOT DING THE HEADERS!! That is a lot of $$$. Call TTI and get thier thoughts. I too thought these were to fit like a glove? One reason for the big $$$.
Mr.Runum
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: 70 Dart TTI header install problems [Re: Mr.Runum] #136550
10/19/08 04:57 PM
10/19/08 04:57 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Is the engine sitting in the chassis according to TTI specifications? I'd call TTI before proceeding.
Re: 70 Dart TTI header install problems [Re: 69Cuda340S] #136551
10/19/08 08:45 PM
10/19/08 08:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
On my 69 Dart I had to use a 1/8" flat washer on the drivers side. There were no issues with the steering box though, it had power that I later converted to manual. My headers are dinged on both sides where the drag link hits them.
Re: 70 Dart TTI header install problems [Re: justinp61] #136552
10/27/08 11:50 AM
10/27/08 11:50 AM
Detroit area
Detroit area
Well, the problem continues. I had some 1 1/4" solid motor mounts made to get the motor up a little higher. Initially there was still contact with the steering box but after tipping the driver side of the motor up a little on the motor mount pads I have about 3'16 to 1/4" of clearance with the steering box. However, the drag link is still rubbing one of the headers tubes when turning the wheels to the left. It seems like the rear of the motor needs to be lifted. I'm thinking about shimming the trans. mount to see if that solves the problem. The k-frame looks to be a correct 67-72 style frame. I just don't understand what could be behind all of these problems.
Re: 70 Dart TTI header install problems [Re: 6PAX] #136553
10/27/08 11:59 AM
10/27/08 11:59 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Is the car on the ground or suspension hanging?
Mine hit the tubes terribly when the suspension was unloaded, but, when on the ground, no rubbing on steering gear. There are some other issues I had, that's another thread...
Re: 70 Dart TTI header install problems [Re: 6PAX] #136554
10/27/08 12:01 PM
10/27/08 12:01 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Sounds like something isnt "stock" in your motor placement.
I have installed TT1 standard head headers on my 70 Duster, and 1 7/8 w5 headers with no issues with either set.
I use solid "stock style" motor mounts, and a factory tranny mount, and have a manual steering box an zero issues with either set of headers.
sounds like your motor/tranny arent sitting in the factory location.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 70 Dart TTI header install problems [Re: B3422W5] #136555
10/27/08 12:26 PM
10/27/08 12:26 PM
Detroit area
Detroit area
Is the car on the ground or suspension hanging? /quote]
The car is on the ground.
I considered that but if something isn't stock I don't know what it is. Everything looks as it should as far as I (and a couple of friends) can tell.
