Any tubbed E-bodies out there?? or at least... #136418
10/14/08 06:42 PM
10/14/08 06:42 PM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
inboard springs?? How wide can you go without tubbing? Got pics?? Does setting the spring boxes in the frame weaken it, strengthen it or remain the same? (That is of course discounting poor workmanship factors such as inferior welds and/or materials)
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136419
10/14/08 06:48 PM
10/14/08 06:48 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I remember a tubbed 70 hemi challenger that ran around these parts back in 79-80. Wow I wonder what happened to that car? I bet that guy about hung himself when the values started to skyrocket because that car was cutup and stripped to be as lite as possible..
Re: Any tubbed E-bodies out there?? or at least... [Re: Challenger 1] #136420
10/14/08 06:59 PM
10/14/08 06:59 PM
Omaha, Nebraska
Omaha, Nebraska
IF I went to the trouble, and thats a very big IF, It would be purely for looks... (I know, I know) I just love the look. Probably wouldn't tub but I would like to stuff the fattest tires I could get under it
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136421
10/14/08 08:00 PM
10/14/08 08:00 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I had a '72 Cuda I did with the Mancini kit and moved them inboard. After that, I fit a 10x28 slick or similar hoosier treaded tire. It was tight to the springs but I was lucky, I had just enough clearance and did not tub the car. Axle got new perches, and leafs got new hangers.
Re: Any tubbed E-bodies out there?? or at least... [Re: Dragula] #136422
10/14/08 08:03 PM
10/14/08 08:03 PM
Dragula Offline
Dragula  Offline
Pick with slicks...
Re: Any tubbed E-bodies out there?? or at least... [Re: Dragula] #136423
10/14/08 08:06 PM
10/14/08 08:06 PM
Dragula Offline
Dragula  Offline
My other Cuda fully tubbed with leafs...
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136424
10/14/08 08:34 PM
10/14/08 08:34 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Cfryer Moparts member.... he had a beauty!
CrAzYMoPaRGuY
Re: Any tubbed E-bodies out there?? or at least... [Re: Dragula] #136425
10/14/08 10:31 PM
10/14/08 10:31 PM
Omaha, Nebraska
Omaha, Nebraska
Stock axle width then?
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136426
10/14/08 10:49 PM
10/14/08 10:49 PM
S.W. Ohio
clyde Offline
clyde  Offline
S.W. Ohio
29x15.5x15 M/T sportsman under mine mini tubbed stock axle
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136427
10/14/08 10:59 PM
10/14/08 10:59 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
With a set of Dr. Diff's offset spring hanger kits you can bolt a B body width rear end,
(2" narrower than a stock E body rear)under an E-body.
Complete bolt in deal, no cutting or welding.
With the correct backspacing this will get you a 15"x10" wheel under the car and a good size tire.
I'm shooting for a 325/50-15 drag radial.
Re: Any tubbed E-bodies out there?? or at least... [Re: KillerBee] #136428
10/14/08 11:42 PM
10/14/08 11:42 PM
Omaha, Nebraska
Omaha, Nebraska
Thanks for the input and replies folks! Gives me food for thought. I surprised that a b body has a narrower axle than a e body?? I always thought it would be as wide or wider being a larger car!
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136429
10/15/08 01:04 AM
10/15/08 01:04 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Remember to use a 68-70 B-body housing, as the 71-74 as wide as the E-body.
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136430
10/15/08 01:18 PM
10/15/08 01:18 PM
Dragula Offline
Dragula  Offline
Yes, just used wheel back spacing to squeeze them in there. Cut the old perches off, and welded new ones on. Double check pinion angle when doing this...
Re: Any tubbed E-bodies out there?? or at least... [Re: KillerBee] #136431
10/15/08 01:58 PM
10/15/08 01:58 PM
Dragula Offline
Dragula  Offline
Rear hangers look a little light for racing purposes...Need beefier ones if your going to run it.
Re: Any tubbed E-bodies out there?? or at least... [Re: Scott Carl] #136432
10/15/08 03:58 PM
10/15/08 03:58 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
my 70 tubbed 4 link/coilover 31x18.5,s hooiser radial,s on15x15 wheel
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Any tubbed E-bodies out there?? or at least... [Re: toplescuda] #136433
10/15/08 10:00 PM
10/15/08 10:00 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
mini tubbed with 31/16.5/15 and a backseat.
Re: Any tubbed E-bodies out there?? or at least... [Re: 70blackfish] #136434
09/24/14 03:48 PM
09/24/14 03:48 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
mine looks a little better now..
Re: Any tubbed E-bodies out there?? or at least... [Re: 70blackfish] #136435
09/26/14 02:59 PM
09/26/14 02:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My Challenger has a mini tub in it to the frame rails with Split Mono leafs & Caltracs.. I currently run 315/60/15 Drag Radials & 29.5"X10.5"W's both on 15" X 12' wheels.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Any tubbed E-bodies out there?? or at least... [Re: 6PKRTSE] #136436
09/27/14 03:27 AM
09/27/14 03:27 AM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
Dr Diff 1" in and a Strange S60 early B body width 15x10 28 X 12.50 R 15 Mickey T's
Still Broke
Re: Any tubbed E-bodies out there?? or at least... [Re: 6PKRTSE] #136437
09/27/14 03:29 AM
09/27/14 03:29 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Similar. My '70 Challenger was mini-tubbed (2.5") by the previous owner + leaf spring relocation kit. I installed Caltracs and their split mono-leaf springs. Rear tires are 315/60-15 BFG Drag Radials with A-body 8.75" rear axle. Wheels are AR500 15x10.
