Re: Any tubbed E-bodies out there?? or at least...
[Re: Challenger 1]
#136420
10/14/08 06:59 PM
10/14/08 06:59 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I remember a tubbed 70 hemi challenger that ran around these parts back in 79-80. Wow I wonder what happened to that car? I bet that guy about hung himself when the values started to skyrocket because that car was cutup and stripped to be as lite as possible..
IF I went to the trouble, and thats a very big IF, It would be purely for looks... (I know, I know) I just love the look. Probably wouldn't tub but I would like to stuff the fattest tires I could get under it
[Re: Dragula]
#136425
10/14/08 10:31 PM
10/14/08 10:31 PM
Scott Carl
Omaha, Nebraska
I had a '72 Cuda I did with the Mancini kit and moved them inboard. After that, I fit a 10x28 slick or similar hoosier treaded tire. It was tight to the springs but I was lucky, I had just enough clearance and did not tub the car. Axle got new perches, and leafs got new hangers.
Stock axle width then?
[Re: Scott Carl]
#136427
10/14/08 10:59 PM
10/14/08 10:59 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
With a set of Dr. Diff's offset spring hanger kits you can bolt a B body width rear end, (2" narrower than a stock E body rear)under an E-body. Complete bolt in deal, no cutting or welding. With the correct backspacing this will get you a 15"x10" wheel under the car and a good size tire. I'm shooting for a 325/50-15 drag radial.
[Re: Scott Carl]
#136429
10/15/08 01:04 AM
10/15/08 01:04 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Thanks for the input and replies folks! Gives me food for thought. I surprised that a b body has a narrower axle than a e body?? I always thought it would be as wide or wider being a larger car!
Remember to use a 68-70 B-body housing, as the 71-74 as wide as the E-body.
[Re: Scott Carl]
#136430
10/15/08 01:18 PM
10/15/08 01:18 PM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
Yes, just used wheel back spacing to squeeze them in there. Cut the old perches off, and welded new ones on. Double check pinion angle when doing this...
[Re: 70blackfish]
#136435
09/26/14 02:59 PM
09/26/14 02:59 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
My Challenger has a mini tub in it to the frame rails with Split Mono leafs & Caltracs.. I currently run 315/60/15 Drag Radials & 29.5"X10.5"W's both on 15" X 12' wheels.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#136436
09/27/14 03:27 AM
09/27/14 03:27 AM
Posts: 916 Arizona
Chucklehead
Arizona
Dr Diff 1" in and a Strange S60 early B body width 15x10 28 X 12.50 R 15 Mickey T's
Still Broke
[Re: 6PKRTSE]
#136437
09/27/14 03:29 AM
09/27/14 03:29 AM
Posts: 401 California, USA
filmsurgeon
California, USA
Similar. My '70 Challenger was mini-tubbed (2.5") by the previous owner + leaf spring relocation kit. I installed Caltracs and their split mono-leaf springs. Rear tires are 315/60-15 BFG Drag Radials with A-body 8.75" rear axle. Wheels are AR500 15x10.
