Race car wiring ?? #1362311
12/31/12 04:18 PM
12/31/12 04:18 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Just finished with the car has a msd 7al 2 box started fine yesterday now it hits only when i let off the start button. Anyone know what is wrong? Thanks
Re: Race car wiring ?? [Re: bobs69] #1362312
12/31/12 04:22 PM
12/31/12 04:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you hook up the run and crank wires together...
MSD you have to.. because you get rid of the ballast res
Re: Race car wiring ?? [Re: MR_P_BODY] #1362313
12/31/12 05:28 PM
12/31/12 05:28 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Yes!!
Re: Race car wiring ?? [Re: bobs69] #1362314
12/31/12 05:36 PM
12/31/12 05:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes!!
Are you getting voltage to the box and coil
Re: Race car wiring ?? [Re: bobs69] #1362315
12/31/12 05:39 PM
12/31/12 05:39 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I hate to tell you this, but I think you box is broken. I had the same thing happen. One way to tell for sure, unhook the “mag” wires, then hook up the “white” wire. Repeatedly ground the white wire, the ignition should spark every time you remove it from ground.
Joe
Without Data, you’re just another guy with an opinion.
Re: Race car wiring ?? [Re: sr4440] #1362316
12/31/12 07:11 PM
12/31/12 07:11 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We have fire at the plugs
Re: Race car wiring ?? [Re: bobs69] #1362317
12/31/12 07:43 PM
12/31/12 07:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well its not the ignition then... do you have fuel..
pump the carb to see a pump shot
Re: Race car wiring ?? [Re: MR_P_BODY] #1362318
12/31/12 07:48 PM
12/31/12 07:48 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Yes we have fuel. The spark at the plugs comes and goes. I think it is the distributor. Good fire from the coil. not a consistant fire on the plugs
Re: Race car wiring ?? [Re: MR_P_BODY] #1362319
12/31/12 08:20 PM
12/31/12 08:20 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mr.P, what happens if you do not get rid of the ballast resistor? I have a digital 6 and did not know you were supposed to get rid of the ballast resistor,I hope I am not hurting my MSD.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Race car wiring ?? [Re: D-50] #1362320
12/31/12 11:32 PM
12/31/12 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its just reducing the voltage... MSD wants lots of
volts... you'll get a hotter spark with full voltage
Re: Race car wiring ?? [Re: bobs69] #1362321
12/31/12 11:37 PM
12/31/12 11:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the carbon ball is in the center of the cap
Re: Race car wiring ?? [Re: MR_P_BODY] #1362322
01/01/13 02:36 AM
01/01/13 02:36 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Changed the cap and rotor. Runs and starts fine
Re: Race car wiring ?? [Re: bobs69] #1362323
01/01/13 02:43 AM
01/01/13 02:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Cool
