Re: Race car wiring ??
[Re: bobs69]
#1362312
12/31/12 04:22 PM
12/31/12 04:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just finished with the car has a msd 7al 2 box started fine yesterday now it hits only when i let off the start button. Anyone know what is wrong? Thanks
Did you hook up the run and crank wires together... MSD you have to.. because you get rid of the ballast res
[Re: MR_P_BODY]
#1362313
12/31/12 05:28 PM
12/31/12 05:28 PM
Posts: 813 ar.
bobs69
ar.
[Re: bobs69]
#1362314
12/31/12 05:36 PM
12/31/12 05:36 PM
MR_P_BODY
Yes!!
Are you getting voltage to the box and coil
[Re: bobs69]
#1362315
12/31/12 05:39 PM
12/31/12 05:39 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I hate to tell you this, but I think you box is broken. I had the same thing happen. One way to tell for sure, unhook the “mag” wires, then hook up the “white” wire. Repeatedly ground the white wire, the ignition should spark every time you remove it from ground.
Joe
Without Data, you’re just another guy with an opinion.
[Re: bobs69]
#1362317
12/31/12 07:43 PM
12/31/12 07:43 PM
MR_P_BODY
We have fire at the plugs
Well its not the ignition then... do you have fuel.. pump the carb to see a pump shot
[Re: MR_P_BODY]
#1362319
12/31/12 08:20 PM
12/31/12 08:20 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mr.P, what happens if you do not get rid of the ballast resistor? I have a digital 6 and did not know you were supposed to get rid of the ballast resistor,I hope I am not hurting my MSD.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1362320
12/31/12 11:32 PM
12/31/12 11:32 PM
MR_P_BODY
Its just reducing the voltage... MSD wants lots of volts... you'll get a hotter spark with full voltage
[Re: bobs69]
#1362321
12/31/12 11:37 PM
12/31/12 11:37 PM
MR_P_BODY
Yes we have fuel. The spark at the plugs comes and goes. I think it is the distributor. Good fire from the coil. not a consistant fire on the plugs
Make sure the carbon ball is in the center of the cap
[Re: bobs69]
#1362323
01/01/13 02:43 AM
01/01/13 02:43 AM
MR_P_BODY
Changed the cap and rotor. Runs and starts fine
Cool
