Small Block Stroker Carb Size #1362192
12/31/12 12:08 PM
12/31/12 12:08 PM
dusterjp Offline OP
dusterjp  Offline OP
What size carb are you guys running on your small block strokers. This car is 99.9% street driven with a trip to the track every 2 to 3 years. Here is my combo. Thanks in advance for all advice.
418 CI
10.9 to 1 Comp.
Ported Edelbrock Heads
Solid Flat Tappet (Dur. 254 Int. 262 Ex.@.050 Lift 540 Int. 555 Ex.)
Ported Super Victor Intake
TTI Step Headers 1 5/8 - 1/78
3.91 Gear
4 Spd.
Wieghs 3200 lbs.
Re: Small Block Stroker Carb Size [Re: dusterjp] #1362193
12/31/12 12:27 PM
12/31/12 12:27 PM
warren, mich.
dwayne welder Offline
warren, mich.
Hello, I like your combination! Should make real good torque for the steet!!! I also like your header combo, very good choice!!! I have Built very simular combo's in sb. chey's. I use a 750 holley, vacuum secondery setup. Good street drivability!!!! You will still need to do some tuningwith,accelerator pump size, some jeting,and secondery spring tuning!!!! But al in al you should be good with that!!!! Good luck, HAPPY NEW YEAR!!!
Re: Small Block Stroker Carb Size [Re: dwayne welder] #1362194
12/31/12 01:13 PM
12/31/12 01:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would run a 950 on that combo. My edelbrocks loved it with a auto so with a stick I think it would even be better.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small Block Stroker Carb Size [Re: dusterjp] #1362195
12/31/12 01:19 PM
12/31/12 01:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
418 CI
10.9 to 1 Comp.
Solid Flat Tappet (Dur. 254 Int. 262 [Email]Ex.@.050[/Email] Lift 540 Int. 555 Ex.)
3.91 Gear
4 Spd.
Wieghs 3200 lbs.
I built a 418 for my Rampage and went with a 850DP
and it made 550hp and 520ftlbs ... this was with W-5
heads and 1 7/8 tubes, same compression.. it would
have made more power with a bigger carb but this was
enough power to put me at my max ET in my car...
strokers really like CFM but it comes down to how
much fuel you want to throw at it on the street
Re: Small Block Stroker Carb Size [Re: MR_P_BODY] #1362196
12/31/12 05:51 PM
12/31/12 05:51 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I have a 800 edelbrock thunder series on my mild 406 stroker in a 68 charger, and it is a perfect match. But I had to buy the carb. tuneup kit to get it to run right.
Re: Small Block Stroker Carb Size [Re: dusterjp] #1362197
12/31/12 06:03 PM
12/31/12 06:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 408 is very close to yours, same compression and heads. I have just a little more duration and more lift with a Victor. Mine loves the Bigs 950HP on it. I'd like to try a 1000 4150 to see if it would pick up.
Re: Small Block Stroker Carb Size [Re: justinp61] #1362198
12/31/12 06:52 PM
12/31/12 06:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Another vote for the Holley 950, Great carb on a stroker SB, but as mentioned any of these big Holleys are THIRSTY! You could probably have just as much fun on the street with a substantially smaller carb (750 range) but you'd leave some HP on the table.
Re: Small Block Stroker Carb Size [Re: ScottSmith_Harms] #1362199
12/31/12 07:03 PM
12/31/12 07:03 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I've gone 9.98@130 mph in my 408 Duster with a 750 holly but will be trying a 850 and a 1050 dom in 2013. I'm a bracket racer and the 750 ran so consistent I didn't want to play with it but like I said its time to test.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Stroker Carb Size [Re: pittsburghracer] #1362200
12/31/12 07:21 PM
12/31/12 07:21 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
Has anyone tried a Pro Systems carb on their stroker? I was talking with their tech and was told their new 750- 4150 series carb could produce 18-35 more horsepower than my current 750 HP Holley. Their carbs are nice looking but I just don’t see how they are that much better than the HP Carbs.
Re: Small Block Stroker Carb Size [Re: gtsdon] #1362201
12/31/12 08:30 PM
12/31/12 08:30 PM
412 SB Duster Offline
I've had great success with Pro Systems carbs. They built me a 780 for my 372. And when I stepped up to the 412 they built me a 950 both ran great out of the box.
Al
Re: Small Block Stroker Carb Size [Re: 412 SB Duster] #1362202
12/31/12 08:46 PM
12/31/12 08:46 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i run a AED850 db pumper on my pumpgas 418 stroker.
Re: Small Block Stroker Carb Size [Re: hp340nos] #1362203
12/31/12 08:59 PM
12/31/12 08:59 PM
Renton Washington
Triple Threat Offline
Renton Washington
I ran a 4150 1000HP and 750HP on my last 390" small block stroker. It made ~550hp. The 1000 was maybe .05 faster than the 750, not a really big gain.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Small Block Stroker Carb Size [Re: Triple Threat] #1362204
01/01/13 03:34 PM
01/01/13 03:34 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
I'll be trying my TQ/Strip Dom combo this yr on my 380. Got to be easier on gas than my 750DP.
Re: Small Block Stroker Carb Size [Re: Belvedere2] #1362205
01/02/13 10:22 PM
01/02/13 10:22 PM
dusterjp Offline OP
dusterjp  Offline OP
Thanks for all the advice.
Re: Small Block Stroker Carb Size [Re: justinp61] #1362206
01/02/13 11:03 PM
01/02/13 11:03 PM
SoCal
Brian Hafliger Offline
SoCal
On the dyno I've seen an additional 5-8 HP over the 950 but haven't tried it at the track.
Brian Hafliger
Re: Small Block Stroker Carb Size [Re: Brian Hafliger] #1362207
01/02/13 11:56 PM
01/02/13 11:56 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i have a 398 stroker and the 1000 was a tenth quicker in the quarter then the 850 with indy intake..
Re: Small Block Stroker Carb Size [Re: 412 SB Duster] #1362208
01/03/13 12:09 AM
01/03/13 12:09 AM
Az
Crizila Offline
Crizila  Offline
Az
Al
Me too. Ran a Prosystems 950 on my 408 NA motor and I'm running the same carb modified by ProSystems om my 408 blower motor.
Fastest 300
Re: Small Block Stroker Carb Size [Re: Crizila] #1362209
01/04/13 02:24 AM
01/04/13 02:24 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Holley HP 950, gonna try a 1050 dommy next
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Small Block Stroker Carb Size [Re: Stroker Scamp] #1362210
01/04/13 07:52 AM
01/04/13 07:52 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Race Demon 1000. I would like to try a holley 950 and a dom but wont fit under hood.
Re: Small Block Stroker Carb Size [Re: Scamp408] #1362211
01/04/13 10:01 AM
01/04/13 10:01 AM
Weddington, N.C.
Streetwize Online content
Streetwize  Online Content
Weddington, N.C.
I run the 1000HP Pro-systems on both my 414 small block and 517 Big Block and I'm very happy with them.
WIZE
In Car:
