Small Block Stroker Carb Size
#1362192
12/31/12 12:08 PM
12/31/12 12:08 PM
Posts: 121 Michigan
dusterjp
What size carb are you guys running on your small block strokers. This car is 99.9% street driven with a trip to the track every 2 to 3 years. Here is my combo. Thanks in advance for all advice. 418 CI 10.9 to 1 Comp. Ported Edelbrock Heads Solid Flat Tappet (Dur. 254 Int. 262 Ex.@.050 Lift 540 Int. 555 Ex.) Ported Super Victor Intake TTI Step Headers 1 5/8 - 1/78 3.91 Gear 4 Spd. Wieghs 3200 lbs.
Re: Small Block Stroker Carb Size
[Re: dwayne welder]
#1362194
12/31/12 01:13 PM
12/31/12 01:13 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I would run a 950 on that combo. My edelbrocks loved it with a auto so with a stick I think it would even be better.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dusterjp]
#1362195
12/31/12 01:19 PM
12/31/12 01:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
418 CI 10.9 to 1 Comp. Ported Edelbrock Heads Solid Flat Tappet (Dur. 254 Int. 262 [Email]Ex.@.050[/Email] Lift 540 Int. 555 Ex.) Ported Super Victor Intake TTI Step Headers 1 5/8 - 1/78 3.91 Gear 4 Spd. Wieghs 3200 lbs.
I built a 418 for my Rampage and went with a 850DP and it made 550hp and 520ftlbs ... this was with W-5 heads and 1 7/8 tubes, same compression.. it would have made more power with a bigger carb but this was enough power to put me at my max ET in my car... strokers really like CFM but it comes down to how much fuel you want to throw at it on the street
[Re: ScottSmith_Harms]
#1362199
12/31/12 07:03 PM
12/31/12 07:03 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've gone 9.98@130 mph in my 408 Duster with a 750 holly but will be trying a 850 and a 1050 dom in 2013. I'm a bracket racer and the 750 ran so consistent I didn't want to play with it but like I said its time to test.
[Re: hp340nos]
#1362203
12/31/12 08:59 PM
12/31/12 08:59 PM
Triple Threat
Renton Washington
I ran a 4150 1000HP and 750HP on my last 390" small block stroker. It made ~550hp. The 1000 was maybe .05 faster than the 750, not a really big gain.
[Re: Crizila]
#1362209
01/04/13 02:24 AM
01/04/13 02:24 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Holley HP 950, gonna try a 1050 dommy next
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
