lower control arms #1359418
12/26/12 05:17 PM
12/26/12 05:17 PM
Hinterland SE Qld Aust
SG duster Offline OP
Is there a difference in length between an A body and B body bottom arm?
Re: lower control arms [Re: SG duster] #1359419
12/26/12 06:53 PM
12/26/12 06:53 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
B and E arms are the same, but A is different.
Re: lower control arms [Re: AtomicDog] #1359420
12/26/12 06:57 PM
12/26/12 06:57 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Correct.
A's are a bit "longer" in overall length, than B & E's.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: lower control arms [Re: hemi71x] #1359421
12/26/12 06:59 PM
12/26/12 06:59 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Correct.
But use a shorter pivot shaft.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: lower control arms [Re: moparmarks] #1359422
12/26/12 07:10 PM
12/26/12 07:10 PM
A bodys are longer? by how much?
the reson Im asking is I have a 68 B body Im replacing a front end in and I have a set of A body arms on the shelf already rebuilt, I was planning to install them rather than rebuild the B body arms, but the car is not here its a few miles away
Re: lower control arms [Re: SG duster] #1359423
12/26/12 07:13 PM
12/26/12 07:13 PM
hemi71x Offline
hemi71x  Offline
I never had to actually measure them, between A body, and B & E body, but they are longer.
Re: lower control arms [Re: hemi71x] #1359424
12/26/12 07:21 PM
12/26/12 07:21 PM
Hmm well thats so not going to work then, I hope the bush is the same size, I have those on the shelf
Re: lower control arms [Re: hemi71x] #1359425
12/26/12 07:23 PM
12/26/12 07:23 PM
hemi71x Offline
hemi71x  Offline
I see your down under in Australia.
Your going to have to rebuild your B body LCA's.
No way getting around it.
Bushings are the same.
Re: lower control arms [Re: hemi71x] #1359426
12/26/12 07:31 PM
12/26/12 07:31 PM
moparmarks Offline
moparmarks  Offline
LCA bushings are the same.
Here is a pis. Upper one is an A and lower is a B/E. A is 1/2" longer and the shaft is a 1/2" shorter.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: lower control arms [Re: hemi71x] #1359427
12/26/12 07:32 PM
12/26/12 07:32 PM
yes, way down in Aust and inland too, at least I dont have to source bushes at this time of the year, Iv done quite a few aussie Val front ends before so its not a biggie for me just that Im here and the car is there with a few miles between, I was hoping for a dismantle reassemble in an afternoon. might have to transport the car home instead
Re: lower control arms [Re: moparmarks] #1359428
12/26/12 07:35 PM
12/26/12 07:35 PM
1/2" who would have thought huh!, the A pivot even looks thinner too
Re: lower control arms [Re: moparmarks] #1359429
12/26/12 07:36 PM
12/26/12 07:36 PM
hemi71x Offline
hemi71x  Offline
moparmarks
Thank's for the picture.
I will be saving it in my photo files in the computer, for future reference.
Jim V.
Re: lower control arms [Re: hemi71x] #1359430
12/26/12 07:51 PM
12/26/12 07:51 PM
moparmarks Offline
moparmarks  Offline
No worries. Thats why I post them. So people can save and use them later.
I love interchange and cross referance.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: lower control arms [Re: moparmarks] #1359431
12/26/12 08:03 PM
12/26/12 08:03 PM
Thanks for sharing, save me a bunch of hassle,
Re: lower control arms [Re: SG duster] #1359432
12/26/12 08:08 PM
12/26/12 08:08 PM
hemi71x Offline
hemi71x  Offline
Stay out of the way of kangaroo's on the highway, when you get it done.
Re: lower control arms [Re: SG duster] #1359433
12/27/12 05:09 PM
12/27/12 05:09 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Old time oval trackers knew about this about 4 decades ago as a stealth way to alter caster/camber figures.
