318 Small Block...what is this? #1351394
12/14/12 08:11 PM
12/14/12 08:11 PM
Roswell, NM
Angel Offline OP
Angel  Offline OP
Roswell, NM
Would someone please tell me what this stuff is in the attached photos? Just next to the coil on my engine there is some wiring that looks like it is connected to a condenser or something. I have always left it alone, but now I'm going to swap this 318 for a 360 and I'd like to know what this is. Will I need it?
Thanks.
Re: 318 Small Block...what is this? [Re: Angel] #1351395
12/14/12 08:18 PM
12/14/12 08:18 PM
Andrewh Offline
Andrewh  Offline
where do the wires go?
year and model of car?
Re: 318 Small Block...what is this? [Re: Angel] #1351396
12/14/12 08:19 PM
12/14/12 08:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's a temperature switch for the electric choke. Depending on engine and ambient temperature, an electric current is used to heat the choke to help it open. If you disconnect it, engine heat will fully open the choke, it will just take a little longer.
Re: 318 Small Block...what is this? [Re: DaytonaTurbo] #1351397
12/14/12 09:37 PM
12/14/12 09:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: 318 Small Block...what is this? [Re: DaytonaTurbo] #1351398
12/14/12 10:09 PM
12/14/12 10:09 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
yup for the electric choke
Re: 318 Small Block...what is this? [Re: Angel] #1351399
12/14/12 11:25 PM
12/14/12 11:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
These guys are 100% WRONG!
It's a sign from Mopar that you need to ditch that carb and intake for a more efficient and powerful arrangement.
- Stu Harmon
Re: 318 Small Block...what is this? [Re: feets] #1351400
12/15/12 04:24 AM
12/15/12 04:24 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Re: 318 Small Block...what is this? [Re: Andrewh] #1351401
12/15/12 11:59 PM
12/15/12 11:59 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
it is a resistor to slow down the choke opening.
Re: 318 Small Block...what is this? [Re: SixDRacing] #1351402
12/17/12 03:07 PM
12/17/12 03:07 PM
Roswell, NM
Angel Offline OP
Angel  Offline OP
Roswell, NM
Thanks to everyone for the answers. It's a 318 in a '73 Plymouth Satellite (my daily driver) but it isn't the original engine. It's date stamped 1984 so who knows what that engine was from...I think I mentioned that in my original post...don't remember.
Anyway, thanks to all for the information. It's no wonder I've never paid any attention to it. It doesn't seem to effect the way the car runs and I've driven through the Chicago WINTER 3 years in a row!
Re: 318 Small Block...what is this? [Re: feets] #1351403
12/17/12 03:09 PM
12/17/12 03:09 PM
Roswell, NM
Angel Offline OP
Angel  Offline OP
Roswell, NM
This was the best answer by the way!
