Re: 318 Small Block...what is this?
[Re: DaytonaTurbo]
#1351398
12/14/12 10:09 PM
12/14/12 10:09 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
It's a temperature switch for the electric choke. Depending on engine and ambient temperature, an electric current is used to heat the choke to help it open. If you disconnect it, engine heat will fully open the choke, it will just take a little longer.
yup for the electric choke
[Re: Angel]
#1351399
12/14/12 11:25 PM
12/14/12 11:25 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
These guys are 100% WRONG! It's a sign from Mopar that you need to ditch that carb and intake for a more efficient and powerful arrangement.
[Re: feets]
#1351400
12/15/12 04:24 AM
12/15/12 04:24 AM
Posts: 1,504 Bradenton, Fl 34203
Kilroy was here
Bradenton, Fl 34203
[Re: feets]
#1351403
12/17/12 03:09 PM
12/17/12 03:09 PM
Posts: 4 Roswell, NM
Angel
Roswell, NM
This was the best answer by the way!
