Re: Grease on Poly Bushings
[Re: mopowers]
#1351266
12/14/12 03:23 PM
12/14/12 03:23 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I use synthetic disc brake caliper grease on all things that move, wiggle slide or spin. It's synthetic and won't attack rubber or plastic has PTFE, Teflon and graphite in it, has a high washout resistance and has an incredible operating temperature range.
There's really nothing out there that I've found that works better for general, long-lasting lubrication on an incredible array of things.
It does cost money, but a little goes a long way. It's often available in very cheap, small blister packs for one time use, but I always get the larger jar with a built in brush.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
