Grease on Poly Bushings #1351263
12/14/12 01:10 PM
12/14/12 01:10 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm putting poly bushings on my leaf springs but lost the grease that came with them. Would I be better off with white grease or a thicker grease like wheel bearing grease??
Re: Grease on Poly Bushings [Re: mopowers] #1351264
12/14/12 02:14 PM
12/14/12 02:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
petroleum based grease is OK, Marine based petroleum is prefered, or Formula 5 from Energy Suspensions
Re: Grease on Poly Bushings [Re: DAYCLONA] #1351265
12/14/12 02:17 PM
12/14/12 02:17 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I don't even know what marine based grease is. HAHA!! I was just trying to get by with what I have.
Re: Grease on Poly Bushings [Re: mopowers] #1351266
12/14/12 03:23 PM
12/14/12 03:23 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I use synthetic disc brake caliper grease on all things that move, wiggle slide or spin. It's synthetic and won't attack rubber or plastic has PTFE, Teflon and graphite in it, has a high washout resistance and has an incredible operating temperature range.
There's really nothing out there that I've found that works better for general, long-lasting lubrication on an incredible array of things.
It does cost money, but a little goes a long way. It's often available in very cheap, small blister packs for one time use, but I always get the larger jar with a built in brush.
Re: Grease on Poly Bushings [Re: jbc426] #1351267
12/14/12 04:42 PM
12/14/12 04:42 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
You'll want the thickest and stickiest grease you can find.
Anything thinner will usually be squished out between over time.
Coat every part of the bushing which sees contact with metal.
The squeaksounds polybushings sometimes develop usually come from the vertical side areas, as they see the most movements.
Re: Grease on Poly Bushings [Re: BigBlockMopar] #1351268
12/14/12 11:25 PM
12/14/12 11:25 PM
IN
ahy Offline
ahy  Offline
IN
I usually have moly grease in my gun and use that on poly. No problems or squeaks.
Re: Grease on Poly Bushings [Re: ahy] #1351269
12/15/12 12:00 AM
12/15/12 12:00 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
I have used Mobil 1 synthetic grease and never had any problems. I would recommend Green Grease for poly bushings over the Mobil 1, because it is thicker and more sticky.
Re: Grease on Poly Bushings [Re: MadMax58] #1351270
12/17/12 03:32 PM
12/17/12 03:32 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Marine grease, its used on outdrive lower legs and looks just like the really expensive stuff that Energy Suspension and others sell. I used this stuff from West Marine, works great!
http://www.westmarine.com/webapp/wcs/sto...;classNum=50819
