Thinking About Getting a Tunnel Ram for My 440
#1351062
12/13/12 09:30 PM
12/13/12 09:30 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
My car is built pretty much like something out of a 1970s Direct Connection catalog as it is anyway, so I'm thinking about putting a Weiand tunnel ram and a pair of Holley 600 1850s on it to make it even more old school.
Current combo is an iron-headed 440 with a Performer RPM, 850 DP, 9.5 Dynamic, 3.91s with a best of 7.96 at 85.6, 1.71 60 foot. I'm thinking a tunnel ram should be good for maybe another couple tenths off in the 1/8?
Way back in the 80s a friend used to run 440 with a tunnel ram, 590 DC cam in a '67 Belvedere street car and I remember it used to cruise fine on the street and was good for mid 12s on regular old L60-15 street tires.
I'm at the point where I'm running out of little things to do to go faster and this seems like a pretty good bang-for-the-buck if I can pick up the intake used. What do you guys think?
Re: Thinking About Getting a Tunnel Ram for My 440
[Re: 67Satty]
#1351063
12/13/12 10:47 PM
12/13/12 10:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have never ran a tunnel ram so I dont know much about them other then when I see dyno test and they use a tunnel ram it always seems to make the most hp. Heck I would go for it as it will definetly look cool and I would think it will go faster. Good luck , Ron
[Re: roadhazard]
#1351069
12/14/12 12:28 AM
12/14/12 12:28 AM
Posts: 553 Kentucky
clovis
Kentucky
My old combo was similar to yours except mine is a 451 (400. I ran 906 heads and had the Weiand TR/1850 combo, it would go 10.90's, we moved to the Mopar 590 cam and traded out the 1850's for a pair of center squirters, we went a best of 10.75 at 3300 lbs. With that combo in my car, it liked rpms. The more I would spin it the faster it would go. I'm not sure I would want to spin a stock rod/piston 440 to 6600 on a regular basis, I was probably living on borrowed time even doing it with the lighter 451/400 combo. So If I was you would I do it, ABSOLUTELY, but it make it work good you will likely need more converter.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: Ari440]
#1351071
12/14/12 01:42 AM
12/14/12 01:42 AM
They definitely add the cool factor, I have always loved tunnel rams. Uploaded with ImageShack.us
[Re: 67Satty]
#1351073
12/14/12 07:41 AM
12/14/12 07:41 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I ran the M1 tunnel ram on a 9 sec 451" street car, I loved it but it drank the fuel cell faster than I could afford to fill it.
[Re: roadhazard]
#1351077
12/14/12 11:50 AM
12/14/12 11:50 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'm gathering the parts now with two 750's Just linkage and another main body, I'm good to go
Oh if your looking for a pair of 1850's drop me a line
Greg,we probably have tops and linkage in the attic.
[Re: Mr.Yuck]
#1351078
12/14/12 12:11 PM
12/14/12 12:11 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I'd like to try the one like ARI440 has, but I'm too cheap...
That intake is supposed to be THE one as the runners are as close to perfect for length for the rpm range most 440's run in. It was never offered with a 2X4 top tho so you would have to build your own.
You see them for sale usually in the $500 range so yes a little spendy for a used intake.
Kevin
[Re: Twostick]
#1351079
12/14/12 12:23 PM
12/14/12 12:23 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Kevin
why would I use 2x4's I already have the six pack....
[Re: Mr.Yuck]
#1351080
12/14/12 12:54 PM
12/14/12 12:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
winning drag week got me a NOS setup for mine
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: B G Racing]
#1351081
12/14/12 12:57 PM
12/14/12 12:57 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Bob I may just have to make a trip to the Hog Pen
