good coil for hei swap
#1350818
12/13/12 12:19 AM
12/13/12 12:19 AM
Posts: 256 libby mt
lifted85
libby mt
ok i did the hei swap a few months back an love it but my flamethrother coil is in need of some love, the studs on top are almost stripped an think it's time for a new 1.. what should i go with a mas blaster coil or a msd street firecoil?? i dont want to mess with running a ballast either if possable
drive fast, drive hard, DRIVE MOPAR
Re: good coil for hei swap
[Re: m88mark]
#1350820
12/13/12 12:29 AM
12/13/12 12:29 AM
RapidRobert
Get a full 12V E coil, no specific recommendation
[Re: RapidRobert]
#1350821
12/13/12 04:27 AM
12/13/12 04:27 AM
Posts: 256 libby mt
lifted85
libby mt
damn i was hopen for somthin that wont bust the bank lol.. thanks guys for the info i will keep shoppin around..
[Re: lifted85]
#1350822
12/13/12 05:08 AM
12/13/12 05:08 AM
Posts: 277 Cincinnati, Ohio
chargincharles
Cincinnati, Ohio
I run a MSD Blaster 2 coil on my HEI conversion. I have a M-body, and that what was recommended on Dippy.org No issues whatsoever with it and it was $50-something dollars 3 years ago when I did the conversion. Probably can pick up one at a swap meet cheaper if you scrounge around enough, or ebay, they are fairly common items. Good luck with it! CC.
[Re: chargincharles]
#1350823
12/13/12 09:32 PM
12/13/12 09:32 PM
Posts: 256 libby mt
lifted85
libby mt
what about the blaster 3 coil?? good or bad??
[Re: lifted85]
#1350824
12/14/12 05:41 AM
12/14/12 05:41 AM
chargincharles
Cincinnati, Ohio
Honestly I have no experience with that coil. I just bought the Blaster 2 and was done with it. If the 3 is a update of the 2 then I don't see where you would have any issues...but that is purely speculation.
[Re: Dunnuck Racing]
#1350826
12/14/12 03:14 PM
12/14/12 03:14 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I did the HEI swap on my '68, and got a coil for a Ford F150 pick-up. I believe the model year was 2001.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1350827
12/15/12 02:24 PM
12/15/12 02:24 PM
Posts: 256 libby mt
lifted85
libby mt
any 1 run the accel super coil part number 140001??
[Re: RapidRobert]
#1350829
12/17/12 06:18 AM
12/17/12 06:18 AM
Posts: 256 libby mt
lifted85
libby mt
well i bougth the accel super coil an a beast it is, it's a big boy lol, should i run a ballist with my set up or or should i be good?? im just runni9ng a hei set up not the junk learn burn...
[Re: RapidRobert]
#1350831
12/17/12 08:58 PM
12/17/12 08:58 PM
Posts: 256 libby mt
lifted85
libby mt
what ballist would ya run? the msd 0.8 ohm or summit G5218 1.6 ohm ballist.. im new to these, every dodge i have owned, 87 ramcharger, 90 w150 an my curent 85 w150 never had 1..
[Re: lifted85]
#1350832
12/17/12 10:31 PM
12/17/12 10:31 PM
RapidRobert
the msd 0.8 ohm
that one. EDIT but ohm it & see what you have. You dont want any more than .8 ohms. I have a black FBO round coil with a MP .25 ohm ballast & it runs flawless so far in a DD
