good coil for hei swap #1350818
12/13/12 12:19 AM
12/13/12 12:19 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok i did the hei swap a few months back an love it but my flamethrother coil is in need of some love, the studs on top are almost stripped an think it's time for a new 1.. what should i go with a mas blaster coil or a msd street firecoil?? i dont want to mess with running a ballast either if possable
drive fast, drive hard, DRIVE MOPAR
Re: good coil for hei swap [Re: lifted85] #1350819
12/13/12 12:26 AM
12/13/12 12:26 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
MAA-30440,PNX-60104 www.summittracing.com
Re: good coil for hei swap [Re: m88mark] #1350820
12/13/12 12:29 AM
12/13/12 12:29 AM
Get a full 12V E coil, no specific recommendation
Re: good coil for hei swap [Re: RapidRobert] #1350821
12/13/12 04:27 AM
12/13/12 04:27 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
damn i was hopen for somthin that wont bust the bank lol.. thanks guys for the info i will keep shoppin around..
Re: good coil for hei swap [Re: lifted85] #1350822
12/13/12 05:08 AM
12/13/12 05:08 AM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
I run a MSD Blaster 2 coil on my HEI conversion.
I have a M-body, and that what was recommended on Dippy.org
No issues whatsoever with it and it was $50-something dollars 3 years ago when I did the conversion.
Probably can pick up one at a swap meet cheaper if you scrounge around enough, or ebay, they are fairly common items.
Good luck with it!
CC.
Re: good coil for hei swap [Re: chargincharles] #1350823
12/13/12 09:32 PM
12/13/12 09:32 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
what about the blaster 3 coil?? good or bad??
Re: good coil for hei swap [Re: lifted85] #1350824
12/14/12 05:41 AM
12/14/12 05:41 AM
Cincinnati, Ohio
Cincinnati, Ohio
Honestly I have no experience with that coil. I just bought the Blaster 2 and was done with it.
If the 3 is a update of the 2 then I don't see where you would have any issues...but that is purely speculation.
Good luck with it!
CC.
Re: good coil for hei swap [Re: chargincharles] #1350825
12/14/12 11:38 AM
12/14/12 11:38 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
That main difference between a blaster two a nd three is the Blaster three is epoxy filled versus oil filled.
Keith
Re: good coil for hei swap [Re: Dunnuck Racing] #1350826
12/14/12 03:14 PM
12/14/12 03:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I did the HEI swap on my '68, and got a coil for a Ford F150 pick-up. I believe the model year was 2001.
Re: good coil for hei swap [Re: jbc426] #1350827
12/15/12 02:24 PM
12/15/12 02:24 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
any 1 run the accel super coil part number 140001??
Re: good coil for hei swap [Re: lifted85] #1350828
12/15/12 03:32 PM
12/15/12 03:32 PM
If that's the big yellow beast yes I ran one on a street 440 30 years ago with no ballast (didn't know any better at the time) & it ran good/never failed. Electronic dist/HEI module. A .8 ohm ballast is recommended with it but like all coil setups you have some leeway on how much pri current you let in
Re: good coil for hei swap [Re: RapidRobert] #1350829
12/17/12 06:18 AM
12/17/12 06:18 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
well i bougth the accel super coil an a beast it is, it's a big boy lol, should i run a ballist with my set up or or should i be good?? im just runni9ng a hei set up not the junk learn burn...
Re: good coil for hei swap [Re: lifted85] #1350830
12/17/12 11:45 AM
12/17/12 11:45 AM
I would for the longevity & you could make back to back outings with and without the ballast to see the power difference just to see what you would gain & check the actual ohms as as a nominal .8 ohm unit may very likely have more than that & I wouldn't be afraid to go a bit less. With a 4 pin ECU I've wired ballasts in parallel to get the ohms down to where I wanted it to be & 2 "single" dual terminal ballasts will fit side by side in a 4 terminal connector (both plastic pieces) & just add another blue loop like the one of em already has
Re: good coil for hei swap [Re: RapidRobert] #1350831
12/17/12 08:58 PM
12/17/12 08:58 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
what ballist would ya run? the msd 0.8 ohm or summit G5218 1.6 ohm ballist.. im new to these, every dodge i have owned, 87 ramcharger, 90 w150 an my curent 85 w150 never had 1..
Re: good coil for hei swap [Re: lifted85] #1350832
12/17/12 10:31 PM
12/17/12 10:31 PM
the msd 0.8 ohm
that one. EDIT but ohm it & see what you have. You dont want any more than .8 ohms. I have a black FBO round coil with a MP .25 ohm ballast & it runs flawless so far in a DD
Re: good coil for hei swap [Re: RapidRobert] #1350833
12/18/12 03:17 PM
12/18/12 03:17 PM
dogdays Offline
dogdays  Offline
A Chevy straight 6 (think 292 in a pickup truck) HEI coil would be a good choice. Also there are coils for '90s Mustangs that are quite good and you can get for cheap.
Neither of them use a ballast resistor.
I wouldn't run a coil that needed one, with that setup.
R.
