Push button shifter cable adjustment. #1349385
12/10/12 11:38 PM
12/10/12 11:38 PM
Great Neck,LI,new york
hemi-itis Offline OP
Do you do the hold in reverse or neutral in park?
When I installed new to me cables{thanks special "K"},I had no one available to come down to the shop to hold in reverse,so I put it in park and adjusted to the neutral saftey switch.I also noticed that the valve body has a "park" position also able to point to the NSS but is not used
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Push button shifter cable adjustment. [Re: hemi-itis] #1349386
12/10/12 11:54 PM
12/10/12 11:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Its a 65 valve body . That's why it has the park pointer. Set it up in neutral. Make sure 3rd is not missing the detent and you'll be good to go.
Doug
Re: Push button shifter cable adjustment. [Re: dvw] #1349387
12/11/12 12:01 AM
12/11/12 12:01 AM
Had a burr in the detent ball bore holding the ball bearing inside the valve body.That was the major contributing factor to me smoking the trans.That has been rectified,replaced the smoked small drum and the clutches & steels that welded themselves together
Re: Push button shifter cable adjustment. [Re: hemi-itis] #1349388
12/11/12 03:25 AM
12/11/12 03:25 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
I set mine up in neutral and then used a dental mirror to be sure the rooster comb detented correctly in R and 1 (both ends of travel)
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: Push button shifter cable adjustment. [Re: MRMOPAR] #1349389
12/11/12 10:34 AM
12/11/12 10:34 AM
Casco, MI
Savoy1964 Online content
Savoy1964  Online Content
Casco, MI
If you have headers make sure the cable is away from the tubes it will melt. I used a hose that just fit the outside diameter of the cable, split it and use it as protection.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Push button shifter cable adjustment. [Re: Savoy1964] #1349390
12/11/12 10:52 AM
12/11/12 10:52 AM
Learned that the hard way
I have used fuel hose UNCUT.slipped it over the cable with a small hose clamp on the bottom side to keep it from leaking.That's for after it get's burnt and starts to leak
Re: Push button shifter cable adjustment. [Re: hemi-itis] #1349391
12/11/12 11:10 AM
12/11/12 11:10 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I usually hold it in reverse push in on the cable,turn the adjuster wheel flush then go two holes past to preload the cable,install the bolt then with the pan off check all the detents.Or look through the neutral switch hole and also check the start in neutral.
Re: Push button shifter cable adjustment. [Re: B G Racing] #1349392
12/11/12 02:32 PM
12/11/12 02:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
I make sure, when I had them, that the pin will drop into the rooster com, after it is adjusted, in nuetral, shift to 1st check it, 2nd and check and finally 3rd gear. Adjust as needed
Re: Push button shifter cable adjustment. [Re: B G Racing] #1349393
12/11/12 05:27 PM
12/11/12 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The adjustment in Reverse only works with the PB valve body, the console/column shift VB must be adjusted in 1st (pull out instead of push in).
The dental mirror is the best final check of proper adjustment.
Re: Push button shifter cable adjustment. [Re: hemi-itis] #1349394
12/11/12 07:34 PM
12/11/12 07:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I finally found the permanent leak repair. Use wiring heat shrink that has the glue in it. Seals tight.
Doug
Re: Push button shifter cable adjustment. [Re: John_Kunkel] #1349395
12/11/12 07:39 PM
12/11/12 07:39 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Your correct,but he was asking for PB adjusting.Usually if you set for positive detent in neutral and it starts your good.
Re: Push button shifter cable adjustment. [Re: B G Racing] #1349396
12/11/12 11:07 PM
12/11/12 11:07 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
When I put my '62 together this year, the neutral "looked" to be in the right spot in the neutral saftey switch hole. I put the neutral safety switch in it, and the car started right up.
Took it down the road and it bound up HARD on the 2~3 shift and would just drag.
What I found is best is to crawl under the dash with the clip removed from the shifter, and push the shifter into it's "detents". Shift the shifter through the gears and make sure the cable easily slides on to the pin shaft of the shifter itself in each gear.
Takes two people, but it's a piece of cake to do it this way.
Re: Push button shifter cable adjustment. [Re: dizuster] #1349397
12/12/12 01:50 AM
12/12/12 01:50 AM
That's pretty much how I did it,except I was alone.So I started out in park which sucks the neutral button in.Adjusted from there,that's when I noticed the "park" position in the valve body that would also engage the n/s switch,the second pointer on the rooster comb.
Re: Push button shifter cable adjustment. [Re: hemi-itis] #1349398
12/12/12 02:42 AM
12/12/12 02:42 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Hay 'itis ! .. just drop-the-pan - put that funky shifter-setup you have in N ...and EYEball it ....and adjust as needed ... ...ORE are you aFearD of getting oily crawling uNder there ? ....
Re: Push button shifter cable adjustment. [Re: dOoC] #1349399
12/12/12 10:24 PM
12/12/12 10:24 PM
Nah,my tile floor pretty easy to keep clean.My vertigo slows me down a tad.Gettin' old sucks
