Push button shifter cable adjustment.
#1349385
12/10/12 11:38 PM
12/10/12 11:38 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Do you do the hold in reverse or neutral in park? When I installed new to me cables{thanks special "K"},I had no one available to come down to the shop to hold in reverse,so I put it in park and adjusted to the neutral saftey switch.I also noticed that the valve body has a "park" position also able to point to the NSS but is not used
Re: Push button shifter cable adjustment.
[Re: hemi-itis]
#1349388
12/11/12 03:25 AM
12/11/12 03:25 AM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
I set mine up in neutral and then used a dental mirror to be sure the rooster comb detented correctly in R and 1 (both ends of travel)
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MRMOPAR]
#1349389
12/11/12 10:34 AM
12/11/12 10:34 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
If you have headers make sure the cable is away from the tubes it will melt. I used a hose that just fit the outside diameter of the cable, split it and use it as protection.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: B G Racing]
#1349392
12/11/12 02:32 PM
12/11/12 02:32 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I usually hold it in reverse push in on the cable,turn the adjuster wheel flush then go two holes past to preload the cable,install the bolt then with the pan off check all the detents.Or look through the neutral switch hole and also check the start in neutral.
I make sure, when I had them, that the pin will drop into the rooster com, after it is adjusted, in nuetral, shift to 1st check it, 2nd and check and finally 3rd gear. Adjust as needed
[Re: B G Racing]
#1349393
12/11/12 05:27 PM
12/11/12 05:27 PM
Posts: 25,879 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The adjustment in Reverse only works with the PB valve body, the console/column shift VB must be adjusted in 1st (pull out instead of push in).
The dental mirror is the best final check of proper adjustment.
[Re: hemi-itis]
#1349394
12/11/12 07:34 PM
12/11/12 07:34 PM
Posts: 9,852 MI, usa
dvw
MI, usa
I have used fuel hose UNCUT.slipped it over the cable with a small hose clamp on the bottom side to keep it from leaking.That's for after it get's burnt and starts to leak
I finally found the permanent leak repair. Use wiring heat shrink that has the glue in it. Seals tight. Doug
[Re: John_Kunkel]
#1349395
12/11/12 07:39 PM
12/11/12 07:39 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Your correct,but he was asking for PB adjusting.Usually if you set for positive detent in neutral and it starts your good.
[Re: dizuster]
#1349397
12/12/12 01:50 AM
12/12/12 01:50 AM
hemi-itis
When I put my '62 together this year, the neutral "looked" to be in the right spot in the neutral saftey switch hole. I put the neutral safety switch in it, and the car started right up.
Took it down the road and it bound up HARD on the 2~3 shift and would just drag.
What I found is best is to crawl under the dash with the clip removed from the shifter, and push the shifter into it's "detents". Shift the shifter through the gears and make sure the cable easily slides on to the pin shaft of the shifter itself in each gear.
Takes two people, but it's a piece of cake to do it this way.
That's pretty much how I did it,except I was alone.So I started out in park which sucks the neutral button in.Adjusted from there,that's when I noticed the "park" position in the valve body that would also engage the n/s switch,the second pointer on the rooster comb.
[Re: dOoC]
#1349399
12/12/12 10:24 PM
12/12/12 10:24 PM
hemi-itis
Nah,my tile floor pretty easy to keep clean.My vertigo slows me down a tad.Gettin' old sucks
