does anybody source this awsome brake st up? #1347246
12/07/12 07:59 AM
12/07/12 07:59 AM
sandwich IL
sublimehemi Offline OP
sandwich IL
ok....i have been reading every disc thread for the last 2 days.....their are too many variables to decide...i was on magnumforce and they have this est up 11.75 X 1.250 rotor with sl-6 wilwood... do they make this bracket kit only cause i want to slowly build this kit i think...i was planning on buying the calipers cheap on ebay and just buying the rotors and caliper bracket from one of our great venders......does anybody have this set up?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347247
12/07/12 08:00 AM
12/07/12 08:00 AM
sandwich IL
sandwich IL
This disc brake conversion uses 11-3/4" x 1.25 thick rotors and Wilwoods big 6-piston Superlite Caliper. Mounts directly to Dodge, Chrysler, Plymouth B or E- body drum brake spindles and uses 11-3/4" diameter rotors. Includes bearings, seals, wheel studs, mounting brackets, rotor adapters, and hubs. Other options include 4-piston Superlite or four piston Narrow Mount Dynalite Calipers, light weight master cylinder, proportioning valve, and residual valve.
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347248
12/07/12 11:07 AM
12/07/12 11:07 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Nice caliper, but the only thing I dont like is the alum hub with no real center register. I'm not sure how you are supposed to make hub centric wheels with that..
Re: does anybody source this awsome brake st up? [Re: BergmanAutoCraft] #1347249
12/07/12 11:30 AM
12/07/12 11:30 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I agree, the hub looks to tapered to offer a solid fit.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347250
12/07/12 11:36 AM
12/07/12 11:36 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Looks like a Wilwood oval track kit. 11.75x1.25 is a popular circle track set up. Check with them (wilwood)as you may be able to find the kit with the part numbers, which will allow you to slowly piece it together. For that matter, anyone who sells Wilwood retail can probably get you a better price than Magnumforce. While your at it, you might be able to substitute the rotors for 12.19 units to gain a bit more leverage.
Since most oval track cars us 1" lug nuts with a 45* seat taper (most street lugs use 60*) and go through regular maintanence inspections, hub centricity isn't a big issue with them.
Re: does anybody source this awsome brake st up? [Re: TC@HP2] #1347251
12/07/12 04:01 PM
12/07/12 04:01 PM
sandwich IL
sandwich IL
good idea ,i too would like to see this in a 12.19....i wonder if 15 in wheels will fit on that 11.75 set up..
Re: does anybody source this awsome brake st up? [Re: BergmanAutoCraft] #1347252
12/07/12 04:47 PM
12/07/12 04:47 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Most custom wheel makers can now machine the register for a wilwood hub.
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347253
12/07/12 04:54 PM
12/07/12 04:54 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
11.75 will fit almost any 15" wheel. That is why the factory went with it. The 12.19 will fit inside some, but not all, 15" wheels, depending on where and how much step is in the hoop. 12.19x1.25 is what the nascar boys are running. Since Wilwood kits are designed with somewhat modular hats and rotors, you can alter rotor diameter, thickness, and offset. Depending on the design of the kit, you may also be able to swap between 4 and 6 piston set ups.
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347254
12/07/12 08:11 PM
12/07/12 08:11 PM
AndyF Offline
AndyF  Offline
You can bolt a Wilwood caliper directly on the factory 11.75 rotor. I started selling the brackets for that swap more than 10 years ago.
Re: does anybody source this awsome brake st up? [Re: AndyF] #1347255
12/07/12 08:40 PM
12/07/12 08:40 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Will that work with A-body spindles Andy?
Re: does anybody source this awsome brake st up? [Re: ScottSmith_Harms] #1347256
12/08/12 06:41 AM
12/08/12 06:41 AM
sandwich IL
sandwich IL
these are 49 dollars at summit ultra light 11.75 x 1.250 deal.....you can even get some that are 30 dollars for plain....pretty good deal if you asked me.i am so building this kit...i called magnumforce today to see if the 12.19 x 1.250 would still work and he said call back he has to check? i am wanting this...the hub assembly,adapter to rotor and drilled rotor is 225.44 each side at summit,or the plain for or 206.46.
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347257
12/08/12 09:41 AM
12/08/12 09:41 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Looks like they will crack easily?
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347258
12/08/12 11:45 AM
12/08/12 11:45 AM
these are 49 dollars at summit ultra light 11.75 x 1.250 deal.....you can even get some that are 30 dollars for plain....pretty good deal if you asked me.i am so building this kit...i called magnumforce today to see if the 12.19 x 1.250 would still work and he said call back he has to check? i am wanting this...the hub assembly,adapter to rotor and drilled rotor is 225.44 each side at summit.
Be careful with those. Even quality drilled rotors are known to crack between the holes. If the car isn't raced/inspected regularly, we suggest to stick with solid rotors.
Re: does anybody source this awsome brake st up? [Re: Dan@Hotchkis] #1347259
12/08/12 02:29 PM
12/08/12 02:29 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If the car isn't raced, I doubt you will crack drilled rotors.
Re: does anybody source this awsome brake st up? [Re: DoctorDiff] #1347260
12/08/12 08:28 PM
12/08/12 08:28 PM
sandwich IL
sandwich IL
or you can run these then lol 5.8 lbs... the drilled in the above pic i posted weigh 7.7....and the plain 32 vane are 8.8....but the 48 vane is 11.5lbs in the 11.75 x 1.25 class....then a 12.19 x 1.25 48 vane is 12.7lbs....and a 32 vave 10.5lbs.......i keep liking this set up more and more.
Re: does anybody source this awsome brake st up? [Re: sublimehemi] #1347261
12/08/12 09:06 PM
12/08/12 09:06 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
or you can run these then lol 5.8 lbs... the drilled weigh 7.7....and the plain 32 vane are 8.8....but the 48 vane is 11.5lbs in the 11.75 x 1.25 class....then a 12.19 x 1.25 48 vane is 12.7lbs....and a 32 vave 10.5lbs.......i keep liking this set up more and more.
I see those every week at the local circle track. Seen them crack too, but under racing conditions. I feel your "passion" I have the same issues, always looking to loose weight on the car, but sometimes race car parts are best left on race cars? Brakes on the street is no place to ride the fine line IMO. Too much is at stake. IMO same with the aluminum hubs.... great on a drag car but no way I would ever run them on the street. But again that's just my opinion, and I'm no "expert" ?
Re: does anybody source this awsome brake st up? [Re: brads70] #1347262
12/08/12 09:28 PM
12/08/12 09:28 PM
sandwich IL
sandwich IL
yeah i was joking when i posted the scalloped rotor....i know those fail..but i am liking the drilled...i think those would do fine for my driving style....and if crack..the rotors are pretty affordable in this size....
Re: does anybody source this awsome brake st up? [Re: ScottSmith_Harms] #1347263
12/08/12 11:09 PM
12/08/12 11:09 PM
AndyF Offline
AndyF  Offline
Yes, the Wilwood adapters work with any spindle that accepts an 11.75 rotor. A/B/E/FMJ knuckles will all work.
Re: does anybody source this awsome brake st up? [Re: AndyF] #1347264
12/10/12 01:16 AM
12/10/12 01:16 AM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
And it works awesome!
Re: does anybody source this awsome brake st up? [Re: Jeremiah] #1347265
12/19/12 11:13 PM
12/19/12 11:13 PM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
HOW ABOUT THE BIG DOG 11.75 ROTOR 1.25 THICK....ON FACTORY SPINDLE WITH ALL FACTORY PARTS
