does anybody source this awsome brake st up?
#1347246
12/07/12 07:59 AM
12/07/12 07:59 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
ok....i have been reading every disc thread for the last 2 days.....their are too many variables to decide...i was on magnumforce and they have this est up 11.75 X 1.250 rotor with sl-6 wilwood... do they make this bracket kit only cause i want to slowly build this kit i think...i was planning on buying the calipers cheap on ebay and just buying the rotors and caliper bracket from one of our great venders......does anybody have this set up?
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: does anybody source this awsome brake st up?
[Re: sublimehemi]
#1347247
12/07/12 08:00 AM
12/07/12 08:00 AM
sublimehemi
sandwich IL
This disc brake conversion uses 11-3/4" x 1.25 thick rotors and Wilwoods big 6-piston Superlite Caliper. Mounts directly to Dodge, Chrysler, Plymouth B or E- body drum brake spindles and uses 11-3/4" diameter rotors. Includes bearings, seals, wheel studs, mounting brackets, rotor adapters, and hubs. Other options include 4-piston Superlite or four piston Narrow Mount Dynalite Calipers, light weight master cylinder, proportioning valve, and residual valve.
[Re: TC@HP2]
#1347251
12/07/12 04:01 PM
12/07/12 04:01 PM
sublimehemi
sandwich IL
good idea ,i too would like to see this in a 12.19....i wonder if 15 in wheels will fit on that 11.75 set up..
[Re: BergmanAutoCraft]
#1347252
12/07/12 04:47 PM
12/07/12 04:47 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
Nice caliper, but the only thing I dont like is the alum hub with no real center register. I'm not sure how you are supposed to make hub centric wheels with that..
Most custom wheel makers can now machine the register for a wilwood hub.
[Re: ScottSmith_Harms]
#1347256
12/08/12 06:41 AM
12/08/12 06:41 AM
sublimehemi
sandwich IL
these are 49 dollars at summit ultra light 11.75 x 1.250 deal.....you can even get some that are 30 dollars for plain....pretty good deal if you asked me.i am so building this kit...i called magnumforce today to see if the 12.19 x 1.250 would still work and he said call back he has to check? i am wanting this...the hub assembly,adapter to rotor and drilled rotor is 225.44 each side at summit,or the plain for or 206.46.
[Re: sublimehemi]
#1347258
12/08/12 11:45 AM
12/08/12 11:45 AM
Dan@Hotchkis
these are 49 dollars at summit ultra light 11.75 x 1.250 deal.....you can even get some that are 30 dollars for plain....pretty good deal if you asked me.i am so building this kit...i called magnumforce today to see if the 12.19 x 1.250 would still work and he said call back he has to check? i am wanting this...the hub assembly,adapter to rotor and drilled rotor is 225.44 each side at summit.
Be careful with those. Even quality drilled rotors are known to crack between the holes. If the car isn't raced/inspected regularly, we suggest to stick with solid rotors.
[Re: DoctorDiff]
#1347260
12/08/12 08:28 PM
12/08/12 08:28 PM
sublimehemi
sandwich IL
or you can run these then lol 5.8 lbs... the drilled in the above pic i posted weigh 7.7....and the plain 32 vane are 8.8....but the 48 vane is 11.5lbs in the 11.75 x 1.25 class....then a 12.19 x 1.25 48 vane is 12.7lbs....and a 32 vave 10.5lbs.......i keep liking this set up more and more.
[Re: sublimehemi]
#1347261
12/08/12 09:06 PM
12/08/12 09:06 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
or you can run these then lol 5.8 lbs... the drilled weigh 7.7....and the plain 32 vane are 8.8....but the 48 vane is 11.5lbs in the 11.75 x 1.25 class....then a 12.19 x 1.25 48 vane is 12.7lbs....and a 32 vave 10.5lbs.......i keep liking this set up more and more.
I see those every week at the local circle track. Seen them crack too, but under racing conditions. I feel your "passion" I have the same issues, always looking to loose weight on the car, but sometimes race car parts are best left on race cars? Brakes on the street is no place to ride the fine line IMO. Too much is at stake. IMO same with the aluminum hubs.... great on a drag car but no way I would ever run them on the street. But again that's just my opinion, and I'm no "expert" ?
[Re: brads70]
#1347262
12/08/12 09:28 PM
12/08/12 09:28 PM
sublimehemi
sandwich IL
yeah i was joking when i posted the scalloped rotor....i know those fail..but i am liking the drilled...i think those would do fine for my driving style....and if crack..the rotors are pretty affordable in this size....
#1347263
12/08/12 11:09 PM
12/08/12 11:09 PM
Posts: 31,068 Oregon
AndyF
Will that work with A-body spindles Andy?
Yes, the Wilwood adapters work with any spindle that accepts an 11.75 rotor. A/B/E/FMJ knuckles will all work.
[Re: AndyF]
#1347264
12/10/12 01:16 AM
12/10/12 01:16 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
And it works awesome!
