Re: wanted throwout bearing hydraulic line
[Re: mxbeep]
#1346213
12/05/12 12:22 AM
12/05/12 12:22 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Any parts store that makes HYD, lines can make what you need, just supply the thread size, line length, etc...you could also go to McMaster Carr com, they can supply just about any line you need, made to your specs
Mike
[Re: DAYCLONA]
#1346214
12/05/12 12:38 AM
12/05/12 12:38 AM
Posts: 1,624 qc
mxbeep
qc
Mike
thanks Mike, but i tried 2 local hydraulic shops and both couldnt get the end lines.
[Re: mxbeep]
#1346216
12/05/12 11:17 AM
12/05/12 11:17 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
i need to purchase a flexible hydraulic line for my Keisler throwout bearing. Keisler only supplies a hard line from the bearing out which is converted to a flexible line.
My hydraulic bearings, including Keisler, came with braided flex lines which I then hard lined to my M/C.
That aside, making braided flex lines using AN fittings is easy. Just Google it.
[Re: mxbeep]
#1346218
12/05/12 08:02 PM
12/05/12 08:02 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
On the throw out side...could you use one of these.. http://www.anplumbing.com/search/index?search_text=305-03M121and use an AN hose with a 90 degree fitting on the end? (Or no room for that even?) There is a really good local hose place here that would be able to whip you something up I bet, TMR in the city of Orange...just not sure if they do mail order or not? Might be a worth a call to them if you have no other luck else where at least.
